Heated Mirrors: Retrofit for Audi A6 Avant 2.5 TDI
inside
Post02-11-2004, 20:02    Subject: Heated Mirrors: Retrofit for Audi A6 Avant 2.5 TDI Quote
hello everyone,
Can anyone give me some tips on retrofitting heated exterior mirrors?
The starting point is electrically adjustable mirrors, but unfortunately, they are not heated. Inside the mirror housings, there are already two black cables, but they do not carry any electricity, not even when the heated rear window is in operation. I've already figured out that they are connected in parallel. Do I just need to replace the mirror glass and run separate cables from the switch to the mirrors for the heating function, or is the process more complicated?
I am grateful for any tips.
Translated on 01-10-2026, 10:15.
Julian
Post02-11-2004, 20:03    Subject: Heated Mirrors: Retrofit for Audi A6 Avant 2.5 TDI Quote
Hmm, normally, this should work with the appropriate glassware. The voltage is pulsed (provided the outside temperature is below 15°C; otherwise, no heating is applied). Did you take that into account in your measurement?
Translated on 01-10-2026, 10:16.
olli
Karma: +46 / -0   Thank you, like it!
Post04-11-2004, 22:04    Subject: Heated Mirrors: Retrofit for Audi A6 Avant 2.5 TDI Quote
If the mirrors are electrically adjustable, they should also be heated. At least, that was the standard configuration from the factory.
It's possible that the mirror glass has been replaced at some point.
Normally, the mirror heating is activated along with the rear window heating when the outside temperature falls below a certain level; I cannot say whether the supply voltage is pulsed or not.
However, the heating effect diminishes over the years; it seems that the resistance of the heater increases, and consequently, only a small amount of current flows.
Heated mirror glass is significantly (!) cheaper to buy from accessory shops than from dealerships.
Olli.
A6 CANA/JME /
Ex-A6 AEL
Translated on 01-10-2026, 10:17.
No new posts Aftermarket Leather Steering Wheel with Airbag Troubleshooting & Guides
No new posts Retrofitting a tow hitch on a Passat 3C, model year 2007 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Speed Control Retrofit Seat Ibiza / Polo Troubleshooting & Guides
No new posts Will 205/60-15 M+S tires on A6 2.5TDI Avant (99) fit? Transmission, Chassis, Body & Interior
No new posts Audi A6 Avant 2.5 TDI Connector (1996) Diesel Engine Technology
No new posts A6 Avant 2.5 TDI AKE - Faulty adjustment by Audi! Diesel Engine Technology
No new posts automatic mirrors Diesel Engine Technology
