Piston Damage? 1994 Car Repair
macgyver68
Post13-11-2004, 14:47    Subject: Piston Damage? 1994 Car Repair Quote
I've been trying to fix the problem with my 1.0L engine for ages. icon_evil.gif It's knocking and smoking blue.
zkd, ventilschaftabdichtung usw. gemacht. drückt das öl durch beide krümmer am 4. Zylinder.
kw-screw, turbo, oil pressure - all good.
Piston rings defective??
Thank you.
Best regards, Manuel.
Translated on 28-08-2026, 6:01.
Julian
Post14-11-2004, 11:17    Subject: Piston Damage? 1994 Car Repair Quote
Valve stem seals need a certain break-in period.
1) What is the warm-up behavior like?
2) Check the compression of the engine when it is at operating temperature.
Translated on 28-08-2026, 6:02.
No new posts Carpet Damage: A3 8P1 Documentation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A3, 8L, front seat lock damaged Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Damaged Threaded Bushing: Repair on Engine Mount? Transmission, Chassis, Body & Interior
No new posts Passat 3BG Tail Light: Damaged? Parts Available. Transmission, Chassis, Body & Interior
No new posts TDI Pistons for VW Sharan Upload
No new posts AVR: 5 Identical Pistons - Explained Diesel Engine Technology
