Do threaded suspension kits require wheel alignment after adjustment?
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
ckone
Post22-11-2004, 17:09    Subject: Do threaded suspension kits require wheel alignment after adjustment? Quote
Is it necessary to have the wheel alignment re-checked if I adjust my coilover suspension? 'Shouldn't only the drop change, then?'
Thank you for the answers.
Forenheini
Post22-11-2004, 17:22    Subject: Subject: Regarding adjustable coilover suspension - wheel alignment adjustment required Quote
Yes... Fine-tuning is necessary because it also changes. Why? After loosening or tightening the tie rods, they will be at a different angle, which will change the alignment.
ckone
Post23-11-2004, 11:38    Subject: Do threaded suspension kits require wheel alignment after adjustment? Quote
Okay, I just called KW, and they said I can adjust it by 1-1.5 cm without noticeably changing the alignment.
What do you think about that statement? Is it possible to calculate how many degrees the trajectory changes?
Post23-11-2004, 11:48    Subject: Do threaded suspension kits require wheel alignment after adjustment? Quote
Sure, you can calculate it by measuring the lengths and using that information to determine the angles, and the rest is trigonometry. Seriously, I think there should be about 1 cm of adjustment needed without you having to make any further adjustments. However, if it were a permanent position, I would be interested in being considered for the role.
Georg-TDI
Post23-11-2004, 12:05    Subject: Do threaded suspension kits require wheel alignment after adjustment? Quote
Okay, I just called KW, and they said I can adjust it by 1-1.5cm without the alignment noticeably changing.
'That's too much, in my opinion!'
(but I'm not an expert in this field)
Sure, you'll still be able to drive it.
But tire change intervals will be drastically reduced!
Don't try to save 30 euros now and then end up paying multiple times for other wear and tear parts; just have the alignment redone properly and that's it!
You certainly want to be able to sleep soundly, right?
Best regards, Georg.
ckone
Post23-11-2004, 13:35    Subject: Do threaded suspension kits require wheel alignment after adjustment? Quote
I actually just wanted to raise the car a bit for the winter so I would have more ground clearance.
In the summer, I would lower it again.
Forenheini
Post23-11-2004, 13:53    Subject: Do threaded suspension kits require wheel alignment after adjustment? Quote
'Hmm... generally speaking, I think that's a rather bold statement from KW... with a misalignment of 1-1.5 cm, it's probably possible to leave it without readjusting the alignment; however, in my opinion, this is only the case if you're close to the stock suspension settings.' The lower the car's suspension is set, the more significant the changes tend to be when adjustments are made, because these adjustments usually don't change linearly.
I would definitely have a survey and, if necessary, an adjustment made. It doesn't cost a fortune, and there are only advantages to it. Especially if you're the one fiddling with it.
Post23-11-2004, 14:04    Subject: Do threaded suspension kits require wheel alignment after adjustment? Quote
I would leave those DIY projects alone.
In my rally car, the suspension height was frequently adjusted, and these adjustments often resulted in significant changes to the vehicle's geometry. This often negatively impacted the handling. I would rather drive a vehicle that is too deep than one where the height needs to be adjusted.
There is still a solution. Measure the vehicle at both heights and find a middle setting that remains within the manufacturer's tolerances for both heights. Unfortunately, this means a huge amount of work, and hardly any workshop will be willing to do it.
Then the statement made by the chassis manufacturer is quite understandable. I highly doubt whether the track and camber values can still be reliably reproduced after the height adjustments.
No new posts VTG Adjustment for VAG TDI Engines Technical Articles
No new posts Adjusting timing and PD element for common rail diesel en... Troubleshooting & Guides
No new posts Adjust the threaded suspension !! Transmission, Chassis, Body & Interior
No new posts Spur einstellen! Ein paar Fragen! Transmission, Chassis, Body & Interior
No new posts Passat 3B Spur einstellen Hinterachse Transmission, Chassis, Body & Interior
No new posts Koni-Gewindefahrwerk einstellen Transmission, Chassis, Body & Interior
