Timing belt replaced on a 1Z engine, year of manufacture 1996
Wolf-Dietmar
Post23-11-2004, 14:33    Subject: Timing belt replaced on a 1Z engine, year of manufacture 1996 Quote
I replaced the timing belt after 100,000 kilometers.
Condition of the timing belt: Very good.
Condition of the tensioner pulley (Ruville): Slight play in the bearing.
Condition of the idler pulley (still original VAG): No play.
Condition of the Conti ribbed belt (with A/C): Severely worn. Broken ribs. Now I finally know where that strange noise was coming from when idling. I had already replaced the tensioner roller, which would have saved me some trouble.
Piston stroke after installing the new belt: 0.48 mm. It had to be readjusted.
I had loosened the camshaft sprocket to allow for the installation of the belt.
I had a huge problem with the right-hand screw (stud bolt/set screw) of the lower timing cover, which had come loose. It took me 2 hours to find a way to get that screw back in without having to completely disassemble the engine.
Question: What are you doing with this screw? icon_rolleyes.gif
Translated on 15-07-2026, 13:01.
No new posts Documentary: Transporter 7D, Timing belt failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A3 ab MJ 98, Zahnriemen läuft auf ESP nicht mittig Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Zahnriemen gewechselt... Diesel Engine Technology
No new posts Kurbelwellenschraube beim AAZ gewechselt Diesel Engine Technology
No new posts Timing Belt Tensioner for PD Engines Diesel Engine Technology
No new posts Timing belt snapped on the SDI! Diesel Engine Technology
