EDC- Reaktion auf kurze Geberunterbrechung | Posts 16+
Go to page: Previous  1, 2
wolfi_b
Post01-12-2004, 13:34    Subject: Quote
Thank you for the information!
I'm going to do some research icon_wink.gif.
However, the main advantage of the relay is that I can switch off the power supply to the GRA using the GRA switch, which causes the relay to drop out. Therefore, even in the event of a malfunction, I can continue driving safely by deactivating the GRA (Gasoline Reduction Assist).
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
hollari
Post01-12-2004, 13:50    Subject: Safety Quote
Yes, you're probably right. If the IC burns out, then...
Does anyone know what might happen?
(Engine starting/running)
I hadn't thought of that.
-> Another idea:
If this brief interruption is actually a problem:
A capacitor between the sensor signal and ground.
(The value would have to be determined through testing.)
I would start with 220 or 470uF.
This, of course, also slows down the effect of the accelerator pedal.
However, I think a good compromise can be found.
(You really don't notice 0.1 seconds, do you?)
wolfi_b
Post01-12-2004, 14:03    Subject: Quote
Thank you!
That might be possible. Let's see...
1993 Audi 80 B4 1Z
No new posts Injection Timing AEL: No Response to Fuel Temp. Diesel Engine Technology
No new posts AUS Engine: Delayed Throttle Response Diesel Engine Technology
No new posts WFS cannot be programmed, no response from STG. On-Board Diagnostics (OBD)
No new posts WFS Function: Quick Question & Explanation Electrical Systems, Vehicle Electronics, Multimedia
