Removing rear door panels on a Golf IV (5-door)
windl
Post28-06-2002, 9:24    Subject: Removing rear door panels on a Golf IV (5-door) Quote
I wanted to remove the rear door panel because the speaker is rattling, but I couldn't get it off. Besides the screws on the sides of the panel, which ones need to be removed?
Alchard
Post28-06-2002, 21:08    Subject: Removing rear door panels on a Golf IV (5-door) Quote
Hi!
If it's similar to the Passat, then there should be two thick metal screws hidden under the handle cover...
Best regards - Alchard
fredi
Post29-08-2002, 19:43    Subject: Removing rear door panels on a Golf IV (5-door) Quote
On the bottom side, there are 2 Torx screws under the handle cover. Remove 2 Phillips head screws. Pry off the cover from the bottom using a small flathead screwdriver. Then, disconnect it from the door and pull it away; it can sometimes be quite tight.
No new posts Audi A4 B6 Rear Door Won't Unlock Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW T6, rear shock absorbers - replacement / weak performance Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Removing and cleaning a diesel particulate filter (DPF) Troubleshooting & Guides
No new posts Starter Motor Removal: VW Golf 3 Guide Diesel Engine Technology
No new posts Golf 2 Speedometer Removal: Guide & Instructions Transmission, Chassis, Body & Interior
No new posts Removing the Climatronic control unit from a Volkswagen G... Transmission, Chassis, Body & Interior
No new posts Removing the heat exchanger, Golf III Transmission, Chassis, Body & Interior
