Replace Steering Column U-Joints (G4/A3)
donalexo
Post05-12-2004, 19:46    Subject: Replace Steering Column U-Joints (G4/A3) Quote
Hello fellow mechanics!
"Has anyone of you ever replaced the constant velocity joints on the steering column of a G4 or A3?"
I have the feeling that these joints are starting to have too much play, which makes it difficult to maintain precise control when turning on narrow country roads.
That's why I've been thinking about replacing these joints. Has anyone here had experience with that?
Are the joints available for individual purchase, or only the entire steering column?
I thought it might even be possible without disassembling the steering column (Optimist icon_biggrin.gif), because by removing the lower dashboard panel, you should be able to access it quite easily.
Thank you for your information.
Alex.
Touran 1.9 TDI, EZ 09/2004
Translated on 23-09-2026, 21:07.
Gremlin
Post05-12-2004, 20:24    Subject: Replace Steering Column U-Joints (G4/A3) Quote
'That joint definitely doesn't appear as a separate part in my AKTE system. The workshop replaced the entire steering column for me.'
It failed after 20,000 km and now has some play again.
classic design flaw...
CU Gremlin.
Translated on 23-09-2026, 21:08.
No new posts Touareg documentation, clacking sounds coming from the st... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Dacia/Renault Duster, squeaking noises steering column / ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Glow Plug Module Replacement - Workshop Special Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 3 Steering Column Transmission, Chassis, Body & Interior
No new posts Steering Column Warranty: What You Need to Know Diesel Engine Technology
No new posts Steering Column Feather & Clip Diesel Engine Technology
No new posts Golf 3 Steering Column Noise: Causes & Fixes Transmission, Chassis, Body & Interior
