1C0 959 799 B Connector Pinout
joergs
Post05-06-2004, 18:01    Subject: 1C0 959 799 B Connector Pinout Quote
Does anyone happen to have the pinout diagram for this (central comfort control unit for Golf/Bora/Passat)?
I urgently need it.
Translated on 21-10-2026, 0:52.
PrivatBereich
Post06-06-2004, 0:15    Subject: 1C0 959 799 B Connector Pinout Quote
Hi Jörg,
Unfortunately, you didn't specify which vehicle you were referring to. I still sent you an email and hope it helps.
Private.
Translated on 21-10-2026, 0:53.
joergs
Post06-06-2004, 11:05    Subject: 1C0 959 799 B Connector Pinout Quote
uuuuuups
Sorry, it's a Passat from 2001 with front and rear fog lights, but without a cabin monitoring system.
But I think your circuit diagram will be helpful...
MSternie
Post31-07-2004, 15:15    Subject: 1C0 959 799 B Connector Pinout Quote
Please also send me the pinout diagram.
'Thank you.'
Translated on 21-10-2026, 0:54.
Theresias
Post08-12-2004, 14:57    Subject: 1C0 959 799 B Connector Pinout Quote
Assuming you've had some success, do you happen to have a part number for a 3B0 959 796 (K)?
joergs
Post08-12-2004, 15:00    Subject: 1C0 959 799 B Connector Pinout Quote
So, the cause of all the problems was a faulty CAN gateway in the back door. However, I only used the wiring diagram to identify the connections for the back door. That's all I did... Unfortunately, I can't help you with the 3B0 959 796 part number... Sorry!
Translated on 21-10-2026, 0:55.
Theresias
Post08-12-2004, 15:02    Subject: 1C0 959 799 B Connector Pinout Quote
So, the cause of all the household problems was a faulty CAN gateway in the back door. However, I only looked up the connections for the back door based on the wiring diagram. That's all I did... Unfortunately, I can't help you further with the 3B0 959 796...} Sorry!}
'Still, thank you... I've been trying to get this thing running in a test environment for the past hour, but with no success...'
Translated on 21-10-2026, 0:56.
joergs
Post08-12-2004, 15:08    Subject: 1C0 959 799 B Connector Pinout Quote
I could possibly look for a wiring diagram for you tonight, if that might be helpful.
Theresias
Post08-12-2004, 15:09    Subject: 1C0 959 799 B Connector Pinout Quote
I could maybe look for a wiring diagram tonight, if that might help you...?
PrivatBereich
Post08-12-2004, 20:58    Subject: 1C0 959 799 B Connector Pinout Quote
You have my email. I hope this helps, although I strongly suspect you may already have this information.
Private.
Translated on 21-10-2026, 0:57.
Theresias
Post08-12-2004, 22:21    Subject: 1C0 959 799 B Connector Pinout Quote
You have email. I hope this helps you, although I strongly suspect that you may already have this information...
Thanks, that confirms what I already suspected... either the storage device is broken, or I haven't installed everything yet.
