abgesenkte LL-Drehzahl und Öldruck | Posts 32+
Go to page: Previous  1, 2, 3
Julian
Post03-12-2004, 18:09    Subject: Quote
AWX, same story: (+2°C).
Cold:
805 revolutions per minute (RPM): 4.3 bar.
945 RPM: 4.3 bar
Warm:
805 U/min: 2.0 bar
945 RPM: 2.1 bar
0W-30 BP Visco 7000 Longlife II.
Translated on 20-08-2026, 15:39.
Post03-12-2004, 18:53    Subject: Quote
Julian wrote:
Warm:
805 U/min: 2.0 bar
945 RPM: 2.1 bar
Well, that sounds pretty good.
It's also somewhat plausible, based on my observation, that even the starter motor can generate at least 0.55 bar of pressure when using 0W30 oil in a warm engine (when the switch is activated).
Translated on 20-08-2026, 15:40.
Julian
Post04-12-2004, 9:52    Subject: Quote
Okay, this also confirms my earlier statement that the AI measures/detects values greater than 2 bar, which no one believed me about before. icon_twisted.gif
The crankshaft only needs to turn about half a revolution before the oil pressure rises, 'long' before the engine even starts. icon_smile.gif
Translated on 20-08-2026, 15:41.
Post04-12-2004, 16:24    Subject: Quote
Julian wrote:
Okay, this also confirms my previous statement that the AI measures/detects pressures above 2 bar, which no one believed me about before. icon_twisted.gif
"Mine only has a switch with a pressure range of 0.55 to 0.8 bar – how can the AI possibly detect a threshold of 2 bar with that?"
Translated on 20-08-2026, 15:42.
Julian
Post05-12-2004, 9:58    Subject: Quote
I have no idea, I just wanted to point out that this value represents the absolute lower limit and only becomes relevant when the engine is completely worn out.
The AI knows the oil pressure, which is 2 bar and corresponds to reality. I just need to figure out how it's being measured.
by the way
@Ulf: Can you read the current oil temperature from the car's computer system? What range is it in, and how does it compare to the coolant temperature?
Translated on 20-08-2026, 15:43.
w123diesel
Karma: +7 / -1   Thank you, like it!
Post05-12-2004, 12:49    Subject: Quote
Here's some information about the oil pumps used in various MKB engines (if anyone is interested).
I found this information in the records (with no guarantee of accuracy).
In the models AQM, AGR, ALH, AHF, ASV, ATD, AXR, AJM, AUJ.
The pump is part number 06A 115 105B and costs approximately €115.
ARL, ASZ 038 115 105B, approximately €130.
In AWX, AVF 038 115 105D.
Unfortunately, I can't say exactly what the difference is.
Translated on 20-08-2026, 15:45.
Post05-12-2004, 14:01    Subject: Quote
Julian wrote:
@Ulf: Can you read the current oil temperature from the car's computer (KI)? What range is it in, and how does it compare to the coolant temperature?
Reading the data is okay, but only via VAGCOM.
So far, I've only tried to maintain it (while exploring the MWB).
It probably won't be worth logging in again until spring/summer, when the system returns to its normal operating temperature for a longer period.
@123diesel: thank you for the information icon_smile.gif.
Translated on 20-08-2026, 15:46.
donalexo
Post05-12-2004, 16:59    Subject: Quote
@JulianViewing profile: Julian:
Can you tell me what thread is on the oil filter flange of the ALH engine? Is it a standard or metric thread (e.g., G1/4", G 3/8", M8, M10, ...)?
I would also like to understand your measurements. I can borrow hydraulic fittings in all sorts of sizes and configurations, but I'd like to know what I need before I unscrew the oil pressure switch.
Then I could also install a pressure sensor (GE), connect it to a 10 bar pressure gauge using a miniature hose, and observe the oil pressure at different temperatures and engine speeds.
Let's see how my AGR engine with almost 170,000 km and the ALH engine with almost 160,000 km compare to each other in a direct comparison.
Alex.
Touran 1.9 TDI, EZ 09/2004
Translated on 20-08-2026, 15:48.
Julian
Post06-12-2004, 16:55    Subject: Quote
@Alex:
Translated on 20-08-2026, 15:49.
donalexo
Post09-12-2004, 21:58    Subject: Quote
Hello Julian!
Thank you for your information. Unfortunately, there are no readily available components of dimension M5 in the hydraulics; I suppose I will have to start building something myself icon_cry.gif.
Is it at least a standard M5 thread, or is it a fine thread? What is the depth of the thread engagement, and what type of sealing is used here?
What type of adapter did you use for the measurement? Is it possibly still available?
Alex.
Translated on 20-08-2026, 15:50.
No new posts VAG 2.0 TDI: No Oil Pressure in Balance Shaft Module Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine temporarily maintains RPM, automatically increases... General Tips
No new posts Oil pressure BSS Diesel Engine Technology
No new posts Oil Pressure & Boost Gauge: Monitor Performance Diesel Engine Technology
No new posts Oil pressure question for V6 engine, MKB: AKN Diesel Engine Technology
No new posts Oil Pressure Sensor 1.6L CAYC Diesel Engine Technology
