Glow plug fuse, Golf III 1.9 TD, manufactured in 1994
doleman
Post11-12-2004, 13:31    Subject: Glow plug fuse, Golf III 1.9 TD, manufactured in 1994 Quote
Hello.
'Since it's gotten colder in the last few days, my car has been very difficult to start and it's been smoking quite a bit. This likely indicates a problem with the glow plug system.' First, I wanted to check the glow plug fuse.
However, it is not located on the splash guard above the brake booster, as indicated in the instruction manual.
Where is she, actually?
Post11-12-2004, 18:43    Subject: Subject: Glow plug fuse for Golf III 1.9 TD, manufactured in 1994 Quote
Where is she actually?
On my 1997 G3 AFN, the bracket was clipped to the top edge of the main electrical unit (above all the relays) -> which was incredibly annoying...
The fuse itself was an oversized flat-pin fuse.
LZ
Post11-12-2004, 20:40    Subject: Glow plug fuse, Golf III 1.9 TD, manufactured in 1994 Quote
Evening.
http://web.utanet.at/langzaur/Relaisbox_Golf3.jpg
Here's the picture; the red/pink thing is in the upper right corner. The relay and the fuse (strip fuse) for the glow plugs of the water circulation system are located on the injection molding wall.
Best regards, Robert.
ekolaus
Post11-12-2004, 21:16    Subject: Subject: Glow plug fuse for Golf III 1.9 TD, manufactured in 1994 Quote
Hello.
Most of the time, it's the glow plugs icon_wink.gif. A blown fuse would be too simple and too cheap.
With the Golf III, it's still manageable to change things, but with the Golf II, I almost went for the big one.
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf, Bora (from 05.00) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 1J bis KW 16/98, Knackgeräusche Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Benötige Kauftip 90 PS TDI/ 101 PS TDI Golf IV, Baujahr ... Diesel Engine Technology
No new posts Golf 3 Baujahr 2/94 Stromlaufpaln für Wegfahrsperre gesu... Diesel Engine Technology
No new posts Vorglühsicherung wo ? Diesel Engine Technology
No new posts Baujahr Injektoren On-Board Diagnostics (OBD)
