Measure Boost Pressure with VAG-Com
TDI-PanTheR
Post11-12-2004, 19:21    Subject: Measure Boost Pressure with VAG-Com Quote
Hi.
Does anyone have instructions on how to measure and log boost pressure using VAG-Com?
And what the test drive is likely to be like.
panther
Translated on 16-09-2026, 18:46.
Post11-12-2004, 20:09    Subject: Measure Boost Pressure with VAG-Com Quote
http://www.dieselschrauber.de/Solldaten_Main.html
Acceleration test: accelerate from approximately 1200 to 4500 rpm in the highest possible gear, using full throttle.
Translated on 16-09-2026, 18:47.
TDI-PanTheR
Post12-12-2004, 23:13    Subject: Measure Boost Pressure with VAG-Com Quote
Good evening.
I was able to measure my boost pressure today.
We also logged some data, but I can't quite make sense of it. Also, the table seems to be a bit jumbled when I open it with Excel.
I hope someone can help me.
I've uploaded the logs.
http://home.arcor.de/planetpanther/diagnose/log-01-002-010-007.csv
http://home.arcor.de/planetpanther/diagnose/log-01-004-010-011.csv
panther
PeterK
Post13-12-2004, 10:09    Subject: Measure Boost Pressure with VAG-Com Quote
hi,
I once converted your CSV file to XLS. In Excel, you need to go to "Data" / "Get External Data" / "From Text" and import the file. When doing so, use a comma as the column delimiter and a period as the decimal separator (using the "More..." button in step 3). This should give you a correctly formatted file.
Someone else needs to interpret it; I can only read it.
Peter K.
-> An Excel file was sent via private message.
golf iv variant
atd 100ps tiptronic
76+ Tkm
t4 womo
aab 78ps und 4 betten, küche, aussendusche
133+ Tkm
Translated on 16-09-2026, 18:48.
No new posts Power Loss: Air Mass/Boost/Timing OK? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Measuring boost pressure On-Board Diagnostics (OBD)
No new posts Measuring boost pressure with VCDS RKS 12.12 Gasoline Engine Technology
No new posts Coolant Temperature Measurement: How To & Guide On-Board Diagnostics (OBD)
No new posts Exhaust Temperature Measurement On-Board Diagnostics (OBD)
