Water Pump Pulley Removal: How-To Guide
golf3schrauber
Post18-12-2004, 21:23    Subject: Water Pump Pulley Removal: How-To Guide Quote
Does anyone have a good tip for me on how to loosen the drive pulley of the water pump?
I can't get those three screws loose without some kind of tool to hold them.
The wheel needs to be removed in order to remove the lower timing belt cover.
Gruss Oliver.
GolfIII,1Z,66KW,von94 mit 500tKm !
Polo 6N,AEE,55KW, von 96
Audi A4 B7, BPP von 2006
Translated on 03-09-2026, 4:26.
tomsyncro
Post18-12-2004, 21:35    Subject: Water Pump Pulley Removal: How-To Guide Quote
hello oliver
It's best to loosen the screws while the serpentine belt is still in place.
or you can hold a screwdriver horizontally across two screws.
and turn the third one, continuing to rotate until all three are open.
Good luck.
"mfg: tomsyncro"
"mfg" is an abbreviation for "mit freundlichen Grüßen," which means "best regards" or "sincerely." "tomsyncro" is likely the name of the sender.
Therefore, the translation of the text is:
"Best regards, tomsyncro"
Translated on 03-09-2026, 4:27.
haehnlein
Post18-12-2004, 22:29    Subject: Water Pump Pulley Removal: How-To Guide Quote
Hello Oliver,
"Those three screws are sticking out a bit: Just use a pair of water pump pliers to hold the entire wheel firmly... or get two long Allen wrenches and use them as a lever."
____________
Kein Auto mehr!
Translated on 03-09-2026, 4:28.
No new posts Document Golf 1J1587, Transmission Console Mounting Not R... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Zahnriemenrad festschweißen? Diesel Engine Technology
No new posts Timing belt pulley, KW brand, worn out - AFN engine Upload
No new posts Timing Belt Pulley Fixed: Repair & Solution Diesel Engine Technology
No new posts Welchen Kleber für Zahnriemenrad 1Z ? Diesel Engine Technology
