Golf 4 Speedometer for VW Vento
Jericho
Post21-12-2004, 16:15    Subject: Golf 4 Speedometer for VW Vento Quote
Enjoy your meal!
My friend would like to install a speedometer from a Golf 4 into his Vento diesel, which is a 1994 model with an AAZ engine. He bought the speedometer and the installation instructions on eBay.
We spent the whole day tinkering today, and everything seems to be working so far. However, in his AAZ engine, the signal for the tachometer is tapped from the alternator. If we now connect the corresponding pin of the Golf 4 speedometer to this signal, the tachometer shows 0 RPM with the engine idling. When you slightly press the accelerator, it jumps up to 5000 RPM and stays there until the engine is turned off.
Does anyone have any advice? I think it's because the AAZ engine doesn't have an ignition control unit from which the signal, as specified in the instructions, should be taken.
Translated on 27-10-2026, 21:25.
gwg
Post21-12-2004, 18:24    Subject: Golf 4 Speedometer for VW Vento Quote
The alternator's speed is significantly higher than the speed reported by the sensor in the engine (control unit)!!!
Günther.
Translated on 27-10-2026, 21:26.
Jericho
Post21-12-2004, 21:48    Subject: Golf 4 Speedometer for VW Vento Quote
Hmm, and what's the solution to this whole dilemma? Should I install a resistor? Should I reset the speedometer on eBay?
Translated on 27-10-2026, 21:27.
Theresias
Post22-12-2004, 1:21    Subject: Golf 4 Speedometer for VW Vento Quote
For the diesel combination instrument panels, a corresponding circuit needs to be built for this conversion, which has been the solution so far.
P.S.: Compare your instructions from the auction house with the following:
httP://theresias.com/tutorials/1h_g4t.htm
Jericho
Post22-12-2004, 9:43    Subject: Golf 4 Speedometer for VW Vento Quote
In general, the instructions I purchased matched the ones linked, but compared to yours, they appear amateurish and lack credibility.
I quickly skimmed through it, but I didn't come across the issue with the tachometer.
Do you have any ideas?
Theresias
Post22-12-2004, 9:45    Subject: Golf 4 Speedometer for VW Vento Quote
The topic (including the issue with the tachometer) is discussed in detail here:
http://www.motor-talk.de/showthread.php?threadid=88105
Translated on 27-10-2026, 21:28.
Jericho
Post22-12-2004, 9:56    Subject: Golf 4 Speedometer for VW Vento Quote
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 1.4 BUD Misfire 2. Cylinder Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Golf 4: Replace Analog Speedometer with FIS Display Transmission, Chassis, Body & Interior
No new posts Headlights Vento/Golf III: Common Problems Transmission, Chassis, Body & Interior
No new posts Golf 3 Speedometer with Golf 4 6-speed? No signal. Diesel Engine Technology
No new posts Golf 4/A3 8L Speedometer, Voltage Regulator On-Board Diagnostics (OBD)
