Webasto Not Working? Troubleshooting Tips.
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
ducmen9
Post20-01-2004, 14:15    Subject: Webasto Not Working? Troubleshooting Tips. Quote
Hi, I've retrofitted a Thermo Top T (DW50) with a T70.
Actually, the thing was working quite well. Now, the system is exhibiting the following behavior:
When I turn it on with the remote control, the internal fan immediately starts, but the unit itself doesn't do anything. When the unit turns off after the set time or is manually turned off, the fan in the outdoor unit continues to run for about 1-2 minutes, accompanied by a clicking sound.
And then it's quiet again. Oh my god, why does this always happen in the winter?
Does anyone have a tip for me?
Thank you in advance! icon_sad.gif icon_sad.gif icon_sad.gif icon_sad.gif icon_sad.gif icon_sad.gif icon_sad.gif icon_sad.gif icon_sad.gif icon_sad.gif icon_sad.gif icon_sad.gif
Translated on 04-09-2026, 17:01.
PrivatBereich
Post20-01-2004, 16:02    Subject: Webasto Not Working? Troubleshooting Tips. Quote
When I turn it on with the remote control, the internal fan immediately starts, but nothing happens with the unit itself.
That sounds like the summer ventilation mode. This mode is designed for summer use. The heater won't turn on, but the interior fan will activate to blow cool outside air into the warm vehicle.
The summer setting is activated via an additional cable, which must be connected to ground. If this cable were to unintentionally short to ground for any reason, the result would be the same.
If the system shuts down after the specified time or is aborted, the fan in the STH starts running and a ticking sound occurs for about 1-2 minutes. Then it becomes quiet again. This doesn't sound like the summer mode operation...
I would suspect the diesel pump is the source of the ticking sound, and that pump only activates when the auxiliary heater is turned on and set to 'winter' mode.
It sounds like the auxiliary heater (when it's interrupted or after a set time) is briefly turning on to heat up and then turning off again.
Everything is very confusing to me. Although it's not really clear, I would check the cable for the summer mode function. (Possibly disconnect it directly at the auxiliary heater.)
Sorry, I don't have a better idea...
If you happen to have a diagnostic interface (e.g., for VAG-COM), you might be able to read the error memory of the auxiliary heater using a corresponding program. Do you have such an interface?
Private.
Translated on 04-09-2026, 17:03.
ducmen9
Post20-01-2004, 18:30    Subject: Webasto Not Working? Troubleshooting Tips. Quote
Thank you for your reply!
I don't have a diagnostic tool yet, but that will be available soon. For now, I'm going to be able to go to a Bosch service center.
Do you think the electronics are messed up?
Translated on 04-09-2026, 17:06.
kini
Post20-01-2004, 18:49    Subject: Webasto Not Working? Troubleshooting Tips. Quote
hi
"I also have a Thermotop installed. On the Thermotop T model, the fuel pump is connected to the combustion air blower, which is mechanically operated. The ticking sound starts as soon as the blower runs. However, the fuel is only pumped when the solenoid valve opens. Perhaps your flame sensor is defective. I could also send you the workshop manual."
Eric
Back to top Profile PM Email
Diesel-Dirk
Post20-01-2004, 22:00    Subject: Webasto Not Working? Troubleshooting Tips. Quote
I would also be interested in the workshop manual.
I've also had my fair share of problems with the Thermo Top T (diesel).
Translated on 04-09-2026, 17:07.
kini
Post20-01-2004, 22:21    Subject: Webasto Not Working? Troubleshooting Tips. Quote
hi
Contact me.
[email protected]
Eric
durnesss
Post21-01-2004, 10:41    Subject: Webasto Not Working? Troubleshooting Tips. Quote
I would also like the manual.
(I have a Tele Thermo Top T with a T70, which was only partially installed new_cry.gif.)
Translated on 04-09-2026, 17:08.
Martin R
Post24-01-2004, 13:39    Subject: Webasto Not Working? Troubleshooting Tips. Quote
With these symptoms, I would suspect a faulty temperature sensor.
ducmen9
Post27-01-2004, 10:04    Subject: Solution works again! Quote
Hello everyone, first of all, a huge thank you to Eric for the PDF!!!
It was the summer setting (which you have to figure out how to access on a T70 without instructions...) combined with air in the lines. I checked almost everything and reassembled the thing. First, I switched it to winter mode (without any comment...), and then I started the system while driving. That got it working again. Now it's nice and warm, and I don't have to scrape the ice anymore!!!!!!!
THANK YOU!!!
Translated on 04-09-2026, 17:09.
kini
Post27-01-2004, 16:27    Subject: Webasto Not Working? Troubleshooting Tips. Quote
hi
You're welcome. I'm glad to hear that it helped you.
Eric
Translated on 04-09-2026, 17:10.
wolle
Post02-12-2004, 16:33    Subject: Webasto Not Working? Troubleshooting Tips. Quote
Hi everyone,
This post is quite old, but is it still possible for someone to email me the manual for the Thermo Top T?
That would be really great!
[email protected]
Thank you and best regards.
Wool.
vagtuning
Post29-12-2004, 19:47    Subject: Webasto Not Working? Troubleshooting Tips. Quote
'Please also send it to me again at [email protected].'
Translated on 04-09-2026, 17:11.
This topic is locked, you cannot edit or reply. Pa 3C BMR Won't Start: Error Code 004160 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A3 8L bis KW 04/2002, Radio schaltet nicht mehr ein Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Webasto Heater Diagnosis: Retrofit Systems Troubleshooting & Guides
No new posts Webasto Termo Top will nicht mehr... Transmission, Chassis, Body & Interior
No new posts Webasto Z/C-D won't start On-Board Diagnostics (OBD)
No new posts 1Z doesn't want to anymore!? Diesel Engine Technology
No new posts TDI 1.9l 1Z startet nicht mehr Diesel Engine Technology
