Hydraulic lifters: Installation and adjustment
bernie123
Post28-12-2004, 21:36    Subject: Hydraulic lifters: Installation and adjustment Quote
Hello forum,
What is meant by "setting" hydraulic lifters, and what should be considered when doing so?
Bernie.
Translated on 14-10-2026, 8:51.
mullemaus
Post28-12-2004, 22:16    Subject: Hydraulic lifters: Installation and adjustment Quote
The hydraulic lifters need to 'settle' after being replaced, meaning that the balancing element (similar to a ball shape) inside the lifters should settle/seat in the lower icon_question.gif position. This allows the lifter to properly fill with oil during startup. icon_wink.gif The waiting time is typically 30 minutes. Do not start the engine during this time.
Translated on 14-10-2026, 8:52.
bernie123
Post29-12-2004, 20:44    Subject: Hydraulic lifters: Installation and adjustment Quote
Hello everyone,
Okay, I've now mostly completed the cylinder head assembly for the Golf 2 D, and I've removed the hydraulic lifters.
(Reversed orientation) reinstalled and tested. One with excessive play, approximately 0.9mm.
"and one with approximately 0.2mm, the others are okay. Question: should I replace them all, or just the worn ones? Where is the wear limit?"
Hi Bernie.
Translated on 14-10-2026, 8:53.
mullemaus
Post29-12-2004, 23:09    Subject: Hydraulic lifters: Installation and adjustment Quote
A set for a TDI (should also fit icon_question.gif or find a suitable one) costs about €38-40 on eBay icon_redface.gif. I would say take a new set icon_smile.gif.
Translated on 14-10-2026, 8:54.
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat Engine Codes AVF & EYF - Parts & Info Diesel Engine Technology
No new posts Euro 4 requirement not as "absolute" as previously thought? Diesel Engine Technology
No new posts Injector Nozzles: Can You Repair the "Tips"? Diesel Engine Technology
No new posts RNS315 Upgrade: Install "Discover Media" Now! Electrical Systems, Vehicle Electronics, Multimedia
