titas wrote: |
| I've already been to the :xfriendly |
place.
They advised me to reorder the VALEO part, as it is definitely the correct one.
Why the BOSCH system was replaced with VALEO, and whether anything was changed in the process, they wouldn't or couldn't tell me! }
One potential issue is likely the pulley (with a freewheel). It's not clear whether other manufacturers offer a pulley with the same mounting, and whether it would also be perfectly aligned.
It seems the only way to do it is to carefully compare the old and the new alternator before installing the new one!
titas}
Was wäre, wenn der freundliche Mitarbeiter zu faul war, die part numbers of the attachments (freewheel, pulley, bracket) to compare in his spare parts catalog?
Or has VAG reached the point where, like with Opel, you can only choose a V-belt by measuring it with a tape measure held against your arm?
Maybe try a different brand of detergent sometime.
Christian.
