Golf, Bora combination instrument panel, 1998 to 04.1999 (Solution)
Michael II
Post05-09-2002, 17:07    Subject: Golf, Bora combination instrument panel, 1998 to 04.1999 Quote
"Content:"
"Code a control unit."
Adjust service interval data.
Adjust fuel level indicator.
Adjust power consumption.
Coding a control unit:
This function allows the circuit breaker module to be coded as follows:
Optional extras.
Country variants.
Number of cylinders.
Encoding for path impulse number.
Composition.
01 Additional equipment: Brake pad wear indicator.
0 Country variant: Germany.
4 inline-four engines.
2 Encoding numbers for path impulse number.
Table:
XX - Code number for optional equipment*.
00 No additional features active.
Brake pad wear indicator active.
02 Seatbelt warning active.
04 Wash water warning active (sensor in the).
Vehicle not currently installed.
16 Navigation
If multiple optional features need to be coded, the code numbers for each optional feature must be added together.
X Country code for locale variant.
0 Germany (D)
1 Europe (EU)
2 United States of America (USA)
3 Canada (CDN)
4 United Kingdom (UK)
5 Japan (JP)
6. Saudi Arabia (SA)
7 Australia (AUS)
X - Cylinder Count Encoding Code.
5 5-cylinder engines.
6 cylinders.
X Coding number for wave number (k-number).
1-4358
2 -3538
3-4146
The code number for the torque value depends on the specific motor/gearbox combination of the vehicle.
1.4L engine, 55kW power output, engine code AHW or AKQ, with manual transmission: 1.
1.6 L / 74 kW, engine code AEH, AKL with manual transmission: 3.
1.9L engine, power output 50kW, engine code AGP, with a 3-speed manual transmission.
All other engine/transmission combinations: 2.
Adjust service interval data:
Channel 10: Service OEL (or OIL), Setpoint = 00015.
Channel 11: service INSP, setpoint = 00030.
Channel 12: Service INSP, Setpoint = 00036.
The target value can only be entered in increments of 1000 km, and the display also shows the value in increments of 1000 km.
The adjustment value must be entered using five digits (e.g., 00009 for an adjustment value of 9).
The target values for service events indicate the value at which the distance and time counters on the service interval display begin to count down.
Function: Adaptation.
Channel: 30.
Range: 120 to 130.
Adjust power consumption display.
It is only possible to adjust the power consumption indicator from 85% to 115%.
The input must be entered in increments of 5%.
Channel: 3
TschĂźss
Michael II
Translated on 15-07-2026, 3:14.
Ratings - Golf, Bora combination instrument panel, 1998 to 04.1999
No new posts Golf, Bora (from 05.00) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Combination instrument, Golf, Bora, 05.99 to 04.2000 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat combination instrument cluster 1998 to 04.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Volkswagen Golf 3, 1999, Immobilizer Gasoline Engine Technology
No new posts Rear Window Regulator Coding VW Golf IV (1999) On-Board Diagnostics (OBD)
No new posts MSTG: Compatible with Golf, Bora, Octavia, A3? On-Board Diagnostics (OBD)
No new posts Golf 4 PD Instrument Cluster Transmission, Chassis, Body & Interior
