Combination instrument, Golf, Bora, 05.99 to 04.2000 (Solution)
Michael II
Post05-09-2002, 17:17    Subject: Combination instrument, Golf, Bora, 05.99 to 04.2000 Quote
Golf and Bora 05.99 > 04.00
Content:
Coding the control unit
Adjusting service interval data
Resetting service interval display
Adjusting fuel level display
Adjusting consumption adjustment
Coding the control unit:
With this function, the dashboard can be coded as follows:
_ Additional equipment
_ Country variations
_ Number of cylinders
_ Coding number for distance impulse count
Composition
01 Additional equipment Brake pad wear indicator
0 Country variation Germany
4 4-cylinder
2 Coding number for distance impulse count
Table:
XX Code number for additional equipment*
00 No additional equipment active
01 Brake pad wear indicator active
02 Seatbelt warning active
04 Washer fluid warning active
16 Navigation
If multiple additional equipment To determine the correct code number, you must add the code numbers for any optional extras.
X Code number for country variant
0 Germany (D)
1 Europe (EU)
2 USA (US)
3 Canada (CDN)
4 Great Britain (GB)
5 Japan (JP)
6 Saudi Arabia (SA)
7 Australia (AUS)
X Code number for number of cylinders
4 4-cylinder
5 5-cylinder
6 6-cylinder
X Code number for number of impulses (K-number)
1 4345
2 3528
3 4134
4 3648
The code number for the number of impulses depends on the engine/gearbox combination of the vehicle:
1.4 l / 55 kW with manual gearbox: 1
1.6 l / 74 kW with manual gearbox: 3
1.9 l / 50 kW-SDI with manual gearbox: 3
1.9 l / 81 kW-TDI with manual gearbox, gearbox code 02M: 4
all engines with 6-speed manual gearbox (including all-wheel drive): 4
all engines with a 6-speed manual gearbox (including all-wheel drive): 4 t 5-speed automatic transmission: 4
all other engine/transmission combinations: 2
Adjust service interval data:
Channel 43
upper limit for distance to inspection. Step size 1000 km
Channel 44
Upper limit for the time until inspection
Step size 1 day
Channel 45
Oil quality of the filled engine oil:
Vehicles with fixed maintenance intervals (PR No.: QG0 and PR No.: QG2):
Input value 00001
Vehicles with gasoline engine and flexible maintenance intervals (PR No.: QG1):
Input value: 00002
Vehicles with 6-cylinder diesel engine and flexible maintenance intervals (PR No.: QG1):
Input value: 00003
Vehicles with diesel engine and flexible maintenance intervals (PR No.: QG1):
Input value: 00004
Channel 40
Distance traveled since the last inspection
Step size 100 km
Channel 41
Time elapsed since the last inspection
Step size 1 day
Channel 46
Total fuel consumption ( (only gasoline engine)
Step: 1 liter
Channel 47
Particulate matter (only diesel engine)
Step: 100 km
Channel 48
Oil consumption (only diesel engine)
Step: 100 km
Reset service interval indicator
Function: Adjustment
Channel: 2
Value: 0
Adjust fuel level indicator
Channel: 30
Range: 120 to 136
Adjust consumption indicator
It is only possible to adjust the consumption indicator from 85% to 115%.
The input must be made in 5% increments.
Channel: 3
Range: 00085 to 00115
TschĂźss
Michael II
Ratings - Combination instrument, Golf, Bora, 05.99 to 04.2000
No new posts Golf, Bora (from 05.00) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf, Bora combination instrument panel, 1998 to 04.1999 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat combination instrument cluster 05.99 to 09.2000 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4 B6 2000 instrument cluster malfunctioning Electrical Systems, Vehicle Electronics, Multimedia
No new posts MSTG: Compatible with Golf, Bora, Octavia, A3? On-Board Diagnostics (OBD)
No new posts Kombiinstrument - Golf 3 Tdi 1Z Bj. ´96 Transmission, Chassis, Body & Interior
No new posts Golf 4 PD Instrument Cluster Transmission, Chassis, Body & Interior
