Hello everyone,
I'm currently in the process of installing an auxiliary battery in my Volkswagen Golf 2. After many problems that I have already solved, two problems currently remain without a solution.
The drive shafts of the G60 or VR6 engines have a diameter that is too small on the transmission side.
The G4 ones don't fit into the wheel hub.
The second problem is the gearbox bearing!
Even after thoroughly studying the parts catalogs for various model types, I searched and found nothing suitable.
Has anyone done this conversion before and can help me with it?
The search function for existing posts wasn't very helpful here, or it didn't lead to the desired results (I didn't find anything).
Sure, here's the translation:
'Thank you very much in advance.'
Christoph
