Passat combination instrument cluster 1998 to 04.99 (Solution)
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
Michael II
Post06-09-2002, 10:55    Subject: Passat combination instrument cluster 1998 to 04.99 Quote
VW Passat, 1998 to 04.99.
Sure, I'd be happy to translate the text for you. Please provide the text you would like me to translate.
Code a control unit.
Adjust service interval data.
Adjust fuel level indicator.
Adjust power consumption.
Coding the control unit:
Composition.
01 Additional equipment: Brake pad wear indicator.
0 Country variant: Germany.
4 inline-4 cylinder engines.
2 Gasoline engine.
Table:
XX Code number for optional equipment*
00 No additional features active.
01 Brake pad wear indicator active.
02 Seatbelt warning active.
04 Wash water alarm active.
16. Navigation
If multiple optional features need to be coded, the code numbers for each optional feature must be added together.
X Country code for locale variant.
0 Germany (D)
1 Europe (EU)
2 USA (US)
3 Canada (CDN)
4. United Kingdom (UK)
5 Japan (JP)
6. Saudi Arabia (SA)
7 Australia (AUS)
X: Cylinder count code.
5 5-cylinder engines.
6-cylinder engine.
X Motorart.
0 Diesel engine.
2 Gasoline engine.
Adjust service interval data:
Channel 10: service OEL (or). OIL), Setpoint = 00015
Channel 11: service INSP, setpoint = 00030.
Channel 12: service INSP, setpoint = 00037.
The target value can only be entered in increments of 1000 km, and the display also shows the value in increments of 1000 km.
The adjustment value must be entered with 5 digits (e.g., 00009 for an adjustment value of 9).
The target values for service events indicate the value at which the distance and time counters on the service interval display begin to count down.
Function: Adaptation.
Channel: 30.
Range: 120 to 130.
Adjust power consumption display.
It is only possible to adjust the power consumption indicator from 85% to 115%.
The input must be entered in increments of 5%.
Channel: 3
Tschüss
Michael II
Ratings - Passat combination instrument cluster 1998 to 04.99
No new posts Kombiinstrument Polo 1998 bis 09.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Kombiinstrument Golf, Bora 1998 bis 04.1999 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat combination instrument cluster 05.99 to 09.2000 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3B, AFN, Bj. 1998, großes Service Diesel Engine Technology
No new posts Kombiinstrument Passat Bj1998 On-Board Diagnostics (OBD)
No new posts Passat 3B Probleme mit Komfortsteuergerät / Kombiinstru... On-Board Diagnostics (OBD)
No new posts Kombiinstrument Passat Modell 2001 Diesel Engine Technology
