Engine Ventilation: Questions and Answers
SST
Post07-09-2002, 15:23    Subject: Engine Ventilation: Questions and Answers Quote
Would it make sense to put the engine ventilation system into a container?
to redirect ?? Like the oil, the AGR also affects the intake path.
pretty full.
Translated on 28-09-2026, 12:35.
Post07-09-2002, 16:32    Subject: Better Alternatives: Find the Best Solution Quote
Hi.
Aside from the fact that the action would likely be quite noticeable (as soon as someone looks under the hood), and that, as far as I know, emissions regulations require a functioning catalytic converter, the oil mist it spits out usually doesn't cause any problems.
Only when it mixes with the soot component of the exhaust gas recirculation system does it form the "nice" sludge that deposits on the intake passages to varying degrees icon_mad.gif.
(If you're already planning to drive illegally, a faulty EGR system is probably the least of your worries.)
Translated on 28-09-2026, 12:36.
No new posts Audi A4 8K, year 2008, engine code CAGA - Engine breather... Diesel Engine Technology
No new posts Non-TDI Questions: Everything You Need to Know Diesel Engine Technology
No new posts Oil Question: Get Answers Now! Diesel Engine Technology
No new posts ASR Issue: Audi 8D/B5 Questions On-Board Diagnostics (OBD)
