Kaltstartproblem-starker Rauch AFN | Posts 16+
Go to page: Previous  1, 2
LuiLatschi
Post13-01-2005, 13:29    Subject: Quote
'There are no scratches or damage. I've taken everything apart, and the pistons and bearing shells look good. You can still see the honing marks in the cylinder walls. The valves aren't bent or damaged anywhere. I'm going to put in two new connecting rods now; hopefully, that will fix it.'
Translated on 11-08-2026, 8:41.
Post13-01-2005, 14:35    Subject: Quote
If that's the case: Good luck, hopefully everything will work again.
Manuel Thomas
Post14-01-2005, 20:33    Subject: Quote
Let the cat out! (or Let the cat run free!)
The oil has also leaked through the exhaust system. When it gets hot, it causes smoke!
Manuel.
Translated on 11-08-2026, 8:42.
LuiLatschi
Post15-01-2005, 7:43    Subject: Quote
I immediately removed the cat when I installed the other turbo; it was completely blocked.
No new posts Document: A4, Emergency Procedure After Strong Acceleration Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4 Doku: Emergency Mode After Heavy Load (KW 09/1999) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Starting Problems 2.5 TDI Engine Diesel Engine Technology
No new posts 1.9 TDI Cold Start Problem Diesel Engine Technology
No new posts Cold start problem 2.5 TDI V6 Diesel Engine Technology
No new posts Cold start problem PD AUY Diesel Engine Technology
