2.5L AKN Engine Not Running - Troubleshooting
crazynemo
Post14-01-2005, 20:42    Subject: 2.5L AKN Engine Not Running - Troubleshooting Quote
Hello!
I installed a 2.5L AKN engine, complete with wiring harness, engine control unit, and all associated components, into an Audi 80 B4.
It won't start!
There is no fuel pressure.
Fuel injection pump, new.
Tax characters OK.
System completely bled.
What could be the problem?
Thank you in advance.
Translated on 28-08-2026, 2:09.
Hati
Post14-01-2005, 21:00    Subject: 2.5L AKN Engine Not Running - Troubleshooting Quote
Hi.
Did he definitely run before?
If that's the case, and if the system is completely bled, I would first check whether diesel is being supplied to the injectors.
If not, does the solenoid valve in the fuel line to the pump open?
Basically, when you're doing a renovation, there are potentially thousands of ways things can go wrong.
Translated on 28-08-2026, 2:11.
crazynemo
Post14-01-2005, 21:17    Subject: 2.5L AKN Engine Not Running - Troubleshooting Quote
The engine had been running previously.
I have fuel (diesel) at the injector, but the pressure is not what it should be.
I've never encountered such a problem before, and I'm honestly at a loss.
Translated on 28-08-2026, 2:12.
Polo2004
Post15-01-2005, 11:19    Subject: 2.5L AKN Engine Not Running - Troubleshooting Quote
I've never had such a problem, and I really don't know what to do anymore.
It actually suggests that there might be a problem with your fuel injection pump.
Best regards, Christian.
mullemaus
Post15-01-2005, 12:45    Subject: 2.5L AKN Engine Not Running - Troubleshooting Quote
Does the V6 engine perhaps have a pre-lift pump in the tank to build up pressure in the system?
Translated on 28-08-2026, 2:13.
bafische
Karma: +22 / -0   Thank you, like it!
Post15-01-2005, 14:01    Subject: 2.5L AKN Engine Not Running - Troubleshooting Quote
mullemaus wrote:
Does the V6 perhaps have a pre-lift pump in the tank? To build up the pressure in the system?
Hot project, well done.
The VP44 is self-priming. While the latest EU IV engines have a pre-lift pump in the tank, its purpose is different from increasing the pre-injection pressure. This is beyond the scope of what we need to discuss.
"If fuel is reaching the injector, you've almost won. What's much more important is what the error codes from the MSG (Main System Module), KI (Engine Control Unit), and GSG (Gasoline Supply Module) are saying. The solution to the problem usually lies there. Also very important: the basic fuel pump setting!"
The VP44 also takes a very long time to self-prime!
Once you've read the error codes, please let me know.
"Luft und Menge müssen stimmen - der Rest ist Physik."
unumstössliches Gesetz in der Dieselmotorenentwicklung
Translated on 28-08-2026, 2:14.
No new posts Engine Idling Low: Troubleshooting & Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Ford with TDCi engine: rough running, stalling General Tips
No new posts Doku A3 ab MJ 98, Zahnriemen läuft auf ESP nicht mittig Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Check Golf 4 VR 5 AGZ catalytic converter, engine running... Gasoline Engine Technology
No new posts BKD engine running rough Diesel Engine Technology
No new posts Motor läuft ohne Pumpenstecker... Diesel Engine Technology
No new posts VW Polo 9N3 1.4L PD DPF (BMS) not running On-Board Diagnostics (OBD)
