Re: Quick question | Posts 32+
Go to page: Previous  1, 2, 3
Gremlin
Post09-09-2002, 22:48    Subject: Re: Quick question Quote
@ Gremlin!
Could it be that more fuel is injected when using fuel with a higher viscosity (thicker, lower temperature)? If so, why?
Best regards, Uwe
With a higher viscosity, the leakage losses in the pump are lower, which slightly increases the injected amount.
Actually, the relationship is the opposite at that temperature. As the temperature increases, the density and viscosity of the diesel decrease, so the injection amount needs to be increased to maintain the power output. That's why the temperature is measured in the pump.
Since the viscosity is not measured, this parameter cannot be controlled or taken into account.
CU Gremlin.
No new posts High consumption General Tips
No new posts 1.4 TSI CTHA - Fuel consumption figures Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Performance Issues: Troubleshooting Guide Diesel Engine Technology
No new posts TDI 1.9: Strange Power Loss - Troubleshooting Diesel Engine Technology
No new posts WBX SS Consumption: Data & Analysis Gasoline Engine Technology
No new posts Calculate Fuel Consumption On-Board Diagnostics (OBD)
