Hi there!
Yesterday, my worn-out brake pad gave up and functioned as a tool for removing burrs.
I set up outside in the rain and started working.
HBZ dissolved and pulled.
No change, but the brake is still stuck.
That wasn't surprising, though!
Brake calipers removed and found to be completely seized.
I had two used items left on the shelf, so I exchanged them.
This weekend, I will test whether the HBZ (likely referring to a specific device or system) functions properly and whether the balancing hole opens correctly.
Don't let the ballast become cemented together because the equalization bore hole is blocked, preventing it from settling properly.
I'll let you know what I found this weekend.
Best regards, Frank.
Translated on 05-08-2026, 13:22.
