Troubleshooter Guest
28-01-2005, 14:52 Subject: Coolant Error: Check Coolant Level Now |
Hey guys,
My Golf has recently started displaying an error message:
STOP: Check coolant level. See operating manual.
The warning only appears when the engine is cold, and it goes away after a few hundred meters. There's definitely enough G12 coolant in the system, and I think it's probably a sensor issue. I would appreciate any tips anyone might have.
Best,
Greetings,
Cheers,
Warmly,
Sincerely,
Best wishes,
Kind regards,
All the best,
Take care,
Love,
XOXO,
Hugs,
See you soon,
Talk soon,
Looking forward to hearing from you,
Hope this finds you well,
Have a great day,
Have a nice weekend,
Best,
Translated on 07-09-2026, 15:35.
Joined: 04/12/2002 Posts: 18088 Karma: +799 / -0 Location: St.Gallen 2018 Volkswagen T6
28-01-2005, 14:54 Subject: Coolant Error: Check Coolant Level Now |
How about you take a look at the coolant reservoir?
Translated on 07-09-2026, 15:36.
Profile PM WWW Garage |
Roger Profi-Schrauber
Joined: 10/11/2002 Posts: 3035 Karma: +88 / -0 Location: Rodgau 2017 Volkswagen Golf Premium Support
28-01-2005, 14:56 Subject: Coolant Error: Check Coolant Level Now |
It can only be due to a sensor, specifically one located in the balancing tank.
Check the connector and cable routing, verschandeln the sensor if necessary, or replace the expansion tank.
The coolant level is determined by measuring conductivity, so a dirty sensor will trigger a false alarm.
//edit: Rainer was faster.  Gruß
Translated on 07-09-2026, 15:37.
Profile PM Garage |
28-01-2005, 21:39 Subject: Coolant Error: Check Coolant Level Now |
Thanks, guys, that's all.
I cleaned the sensor (the wire clip) in the coolant reservoir using an old toothbrush, and the annoying beeping stopped.
Thank you for the tip.
Best,
Greetings,
Cheers,
Warmly,
Sincerely,
Best wishes,
Kind regards,
All the best,
Take care,
Love,
XOXO,
Hugs,
See you soon,
Talk soon,
Have a great day,
Best,
Translated on 07-09-2026, 15:38.
