Idle Cutting & Partial Load, 4th & 5th Gear
manni
Post04-02-2005, 23:10    Subject: Idle Cutting & Partial Load, 4th & 5th Gear Quote
Hi everyone, my Audi 80 TDI 1Z, manufactured in 1994, is experiencing the symptoms described above... the shaking/jerking stops when the speed signal is disconnected.
I'm pressing the button on the turnout control panel, and I've already tried a few resets, but unfortunately, nothing has worked. Has anyone ever opened this turnout control panel (HDK) before? If so, could you tell me what's important to look for? Thank you in advance!
Best regards, Manni.
Translated on 07-09-2026, 23:54.
joergs
Post04-02-2005, 23:18    Subject: Idle Cutting & Partial Load, 4th & 5th Gear Quote
Have you ever used the search function?
Then you would have found this.
Translated on 07-09-2026, 23:55.
No new posts Documented noises from the dual-clutch transmission, 6-sp... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Gear Noise, 6-Speed Transmission Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Gearbox 02K: 3rd Gear Hard to Shift Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Repairing Partial Collision - AFN Diesel Engine Technology
No new posts Advertising with Partial Truckloads? Diesel Engine Technology
No new posts 5-Speed Gearbox: Sharan/Alhambra/Galaxy (AFN) Change? Diesel Engine Technology
No new posts Golf 5 1.9 TDI 5-speed 6-speed gearbox ZMS clutch Diesel Engine Technology
