Leistungsverlust Magnetventil / Saugrohrdruck / Regeldiff. | Posts 16+
Go to page: Previous  1, 2
chrisgtd1
Post22-10-2004, 6:12    Subject: Quote
Hello everyone, is there any news? What's causing the error?
because I think I have the same problem.
And to be honest, I'm starting to think I should also replace the mass airflow sensor, the pressure sensor in the charge air hose, and the solenoid valve.
because then everything else is ruled out, leaving only the pump as the possible cause.
'But otherwise, I'm experiencing the exact same problem: at 3200 RPM in the 4th and 5th gears, I'm getting little to no power.'
performance
Okay, greetings to Chris.
from Stuttgart
Translated on 18-09-2026, 18:40.
bened
Post08-02-2005, 11:54    Subject: Quote
It's a shame that no one is continuing this discussion!
I'm having the same problem.
Translated on 18-09-2026, 18:41.
Post08-02-2005, 12:08    Subject: Quote
Really? Did they install the wrong engine and break the nipple on the wastegate?
Translated on 18-09-2026, 18:42.
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0046 - Turbocharger Boost Control Circuit Malfunction, M... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VTG Issues: Emergency Mode, Intake Manifold Pressure Regu... Troubleshooting & Guides
This topic is locked, you cannot edit or reply. Solenoid Valve: Troubleshooting Performance Loss Diesel Engine Technology
No new posts Boost control solenoid valve. Power loss (A3 TDI) Diesel Engine Technology
No new posts AFN Emergency Mode - 575 Sauerstoff Sensor Control Unit -... Diesel Engine Technology
No new posts Boost Control Valve: Limit Charge Pressure Diesel Engine Technology
