Approximately 4 weeks ago, I converted the manual air conditioning system in my Golf III (built in 1997) with an AFN engine to Climatronic. To do this, it was necessary to have the refrigerant extracted so that the climate control unit could be replaced. So far, so good. Today, I received a new dryer from E*** and immediately wanted to install it. The seals for the lines that I bought from VW didn't fit; great! Full of hope, I drove to the nearest ATU service center to buy the correct seals and have the system filled. Unfortunately, they didn't have time today.
OK,
However, the master technician from ATU told me that the dryer needs to be filled with oil. Apparently, this requires removing the dryer, turning it upside down, and filling it with oil?!?!?
To the best of my knowledge, 80% of the air conditioner's oil is inside the compressor, while the rest circulates in the pipes and elsewhere.
Okay, so what's the right way to do this? In my opinion, you shouldn't need to add any oil to the dryer because R134a already has lubricating properties, right?! Besides, wouldn't it be easier to just put the oil into the regular filling ports instead of having to take the dryer out, turn it around, and then fill it?
I am confused and would like an answer.
Achim
