KSB solenoid valve for Bosch VEP 0460484067
guido76
Post09-02-2005, 1:47    Subject: KSB solenoid valve for Bosch VEP 0460484067 Quote
'In the mentioned fuel injection pump (Fiat Punto 1.7TD), the fuel shut-off valve (KSB) is operated by a temperature sensor and (I believe) a solenoid valve. When I apply 12V to the solenoid valve, I don't hear or feel any clicking, and I don't notice any difference with the engine running. Since the car also exhibits some knocking when warm, I'm looking for the cause, and I've noticed that the knocking decreases when I adjust the fuel injection timing to a later setting (?). Could the solenoid valve be stuck or defective (the car starts well even in cold weather)? ' Can I get this part individually? There's a number '113.05' on the key surface; is that a part number that someone might be able to use? Also, what is the part number, and perhaps someone knows an approximate price?
guido76
Post10-02-2005, 22:10    Subject: KSB solenoid valve for Bosch VEP 0460484067 Quote
Has anyone ever disassembled the solenoid valve of a Bosch distributor injection pump's cold start accelerator/injection timing adjuster, or experienced a defect in it? If so, please give me some advice on how to test it. What resistance should I measure between the solenoid and ground? Does the valve only open a bore in the direction of the injector's piston, or how does the whole thing work?
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0046 - Turbocharger Boost Control Circuit Malfunction, M... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Grundeinstellungen für Bosch ABS/ESP 5.3 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Magnetventil,Spritzversteller N108,Motor 1Z,Bosch 0281002136 Diesel Engine Technology
No new posts Magnetventil für AGR und VTG vertauschen On-Board Diagnostics (OBD)
No new posts Teilenummer Magnetventil AGR Diesel Engine Technology
No new posts Magnetic valve for charging pressure regulation Diesel Engine Technology
