I'm having a problem with the logs for K-Power. Specifically, my speed signal is 'acting up'
I have tried various measurement devices using VAG-COM Ver.409.1 (Shareware + DIY adapter
), and all values can be easily read and logged. However, the crucial km/h values randomly jump to the actual speed
, resulting in no correct measurement values
, and K-Power is not possible.
The speedometer is working perfectly; there are no erratic readings or anything like that.
The error log shows an 'implausible speed signal'
. The error was cleared, and a new measurement was performed. The result is that when accelerating, the km/h display works correctly. However, when disengaging at maximum RPM, it shows 0 km/h, and then various km/h readings
. This measurement is useless
After that, the car was parked (ignition off and on), and the error memory was read again
. Empty, no entries
I've done some digging through the search results and have come to the following conclusion (please correct me if anything is wrong
There is a sensor that provides a speed signal, outputting two signals. One signal goes to the control unit (KI), and the other goes to the engine control unit (ECU).
The signal for the AI seems to be working correctly, as the speedometer is functioning properly.
with the other signal, something isn't right (possibly a loose connection
, as it works when accelerating).
My question is, where is the installation location of this sensor (is it called a G22 speed sensor? Apparently, it seems to be called that according to my search
Are these both the same signals, or do the Mstg and the KI operate with different signals?
From that, I could draw conclusions about whether the sensor is defective or if there's a problem with the 'signal line' leading to the MSTG (Multi-Sensor Test Gauge).
Can I measure anything there? The signal is probably only measurable while the vehicle is in motion
I've encountered the 'implausible vehicle speed' error multiple times, and after clearing it, I haven't noticed any negative effects while driving. There's been no hesitation, no loss of power.
Thank you in advance.
'MFG' is an abbreviation for 'mit freundlichen Grüßen,' which means 'best regards' or 'sincerely.' It is commonly used in German-language emails and letters.
