Replacing control arm bushings on an Audi 80 TDI
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
haehnlein
Post18-09-2002, 16:08    Subject: Replacing control arm bushings on an Audi 80 TDI Quote
Hello!
"The ball joints on the control arms of my Audi 80 are worn out. I would appreciate any tips on how to remove them without a press (using a socket?). For example, with my old Passat from 1985, I smashed the rear axle bushings radially with a chisel until they popped out (I'm not sure if that works for control arm ball joints!)."
Thank you in advance!!!!
Translated on 19-07-2026, 11:37.
Post18-09-2002, 16:15    Subject: Replacing control arm bushings on an Audi 80 TDI Quote
How about using a thick threaded rod, two nuts, and a pipe for support?
Insert the threaded rod into the tube, and then place the tube onto the control arm, passing the threaded rod through the bushing that needs to be removed.
The pipe must have a larger inner diameter than the sleeve being removed. Alternatively, two angle irons can be used for support.
Then, add two suitable nuts or similar items onto the threaded rod, place the nut on top, and tighten icon_smile.gif.
-> It costs almost nothing, and with an M12, you can pull quite a bit.
Translated on 19-07-2026, 11:38.
haehnlein
Post18-09-2002, 16:24    Subject: Replacing control arm bushings on an Audi 80 TDI Quote
That sounds great! Thank you very much.
Translated on 19-07-2026, 11:39.
No new posts Ignition Switch Replacement VW Golf 3 Troubleshooting & Guides
No new posts Glow Plug Replacement: 2.0L TDI 16V Troubleshooting & Guides
No new posts Replacing the Gearbox Seal between the Gearbox and the Dr... Troubleshooting & Guides
No new posts Should I replace the crankshaft center bolt on a 1Z TDI e... Diesel Engine Technology
No new posts Lenkgetriebe beim A4 wechseln Transmission, Chassis, Body & Interior
No new posts ZR beim AKN selbst wechseln? Diesel Engine Technology
No new posts G40 Sensor am CR Diesel wechseln (Audi A3 8V 2.0 TDI) Diesel Engine Technology
