Audi A4 documentation, fault in the secondary air system (Solution)
Post10-03-2005, 15:14    Subject: Audi A4 documentation, fault in the secondary air system Quote
Author: Michael II
2.4L and 2.8L V6 engines.
Exhaust warning light is illuminated, secondary air system malfunction.
Cause:
The engine control unit's fault memory indicates an error code for the secondary air system on bank 1, specifically "faulty flow rate" or "insufficient flow."
The cause is a kinked vacuum hose on the combination valve for secondary air.
Solution:
Check all vacuum lines in the secondary air system for leaks and kinks.
If the vacuum hose on the combination valve for secondary air needs to be replaced, then it should be replaced. It should be extended by 20 mm.
Please provide the German text you would like me to translate.
Bye.
Michael.
Ratings - Audi A4 documentation, fault in the secondary air system
No new posts Doku Audi, Fehler am Elektrolüfter Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4: Airbag System Error - Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A4 8D, valid until 06/2000, issue with defroster... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi S6 fuel filler cap error Electrical Systems, Vehicle Electronics, Multimedia
No new posts Audi A3 CFGB, AGR-Fehler Diesel Engine Technology
No new posts Error 01130 ABS operation on Audi S3 On-Board Diagnostics (OBD)
No new posts Audi A8: Fuel Injection Error - Limp Mode? On-Board Diagnostics (OBD)
