Audi A4 Noise: Gurgling Sounds (Up to 01/99) (Solution)
Post10-03-2005, 15:16    Subject: Audi A4 Noise: Gurgling Sounds (Up to 01/99) Quote
Author: Michael II.
"While idling, a bubbling or gurgling sound can be heard in the front right area."
Cause:
A ventilation hose runs from the activated carbon filter container downwards to the vehicle floor and outside. The hose is routed in a bend where condensation accumulates. During operation, the intake of fresh air then causes the noises described.
Solution:
After removing the front right wheel arch liner, you can access the ventilation hose of the activated carbon filter housing. This hose runs from the bottom of the housing to the vehicle floor and then to the outside.
Where the hose bends upwards, a 3 mm hole should be drilled in the hose at its lowest point, allowing any water accumulation to drain downwards.
Please provide the German text you would like me to translate.
Bye.
Michael.
Translated on 29-09-2026, 14:34.
Ratings - Audi A4 Noise: Gurgling Sounds (Up to 01/99)
No new posts Document A3, 8L, front seat lock damaged Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Passat 3B, Seatbelt front does not retract properly Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Audi 8P, Control Lamp Test Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Retrofitting front parking sensors Electrical Systems, Vehicle Electronics, Multimedia
No new posts Overhaul front brake caliper Transmission, Chassis, Body & Interior
No new posts T5 Front Wheel Bearing Replacement Transmission, Chassis, Body & Interior
No new posts Clicking Noise? Car Problems & Solutions. Diesel Engine Technology
