Webasto DW50 Water Heater: Circulation & Installation
HangingSQRL
Post04-02-2005, 8:29    Subject: Webasto DW50 Water Heater: Circulation & Installation Quote
Good morning, everyone...
I'd like to ask if anyone in this community has ever installed a Webasto auxiliary heater (standby heater) in an Audi A3 (8L) 1.9TDI PD 131PS with Climatronic, or had one installed.
I bought a used A3, but the auxiliary heating system isn't working properly.
The previous owner had a Webasto DW50 installed. I've already read on this forum that the DW50 is not good due to its high return temperature, etc.
I want to completely rewire the auxiliary heater because the water circuit connection was also installed incorrectly... (wrong circulation direction!).
My questions:
How did you install your turbocharger cooler (intercooler) in your A3 8L? Where did you connect it to the cooling system? [Optional: Include pictures]
Does anyone else besides me have a DW50 installed in a PD?
Does it work smoothly when integrated into the return flow?
best regards
HangingSQRL
Translated on 29-09-2026, 2:39.
vagtuning
Post13-03-2005, 19:47    Subject: Webasto DW50 Water Heater: Circulation & Installation Quote
How do you mean that about the incorrect flow direction?
Images?
Translated on 29-09-2026, 2:41.
gwg
Post13-03-2005, 23:56    Subject: Webasto DW50 Water Heater: Circulation & Installation Quote
What do you mean by the incorrect direction of circulation??
Pictures ??
Incorrect water flow direction in the heating system!
Günther
mcgregg
Karma: +7 / -1   Thank you, like it!
Post14-03-2005, 20:06    Subject: Webasto DW50 Water Heater: Circulation & Installation Quote
I have an Octavia with a VP 37 and an Eberspächer D4WSC (see signature). The auxiliary heater is mounted at the front on the left side, behind the bumper. It is integrated into the water circuit between the cylinder head (suction side of the heater) and the heat exchanger (pressure side of the heater).
Circulation direction? Let's start at the heat source and end there as well: auxiliary heater, heat exchanger, engine block, auxiliary heater.
I can't think of any plausible reason why it would be different for other vehicles based on the Golf IV platform or for Webasto products.
Regards, mcgregg.
Skoda Octavia II Combi TDI, 2012, 103kW/140PS MKB CFHC
Translated on 29-09-2026, 2:42.
No new posts VW T4 AHY: Defective Auxiliary Heater / Parking Heater Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
No new posts Standheizung Einbau: D5WSC mit Easystart R+ Installation Troubleshooting & Guides
No new posts Webasto Thermo Top T DW50 Installation Guide A6 2.5 TDI Transmission, Chassis, Body & Interior
No new posts Auxiliary Heater for V6 TDI Engine Diesel Engine Technology
No new posts Standheizung??? Diesel Engine Technology
No new posts Heated Seats Audi A6 2.5 TDI V6 Diesel Engine Technology
