Valve cover gasket leak - unfortunately, also on the timing belt.
jensg
Post01-04-2005, 14:29    Subject: Valve cover gasket leak - unfortunately, also on the timing belt. Quote
bei unserem G4 ist die Ventildeckeldichtung undicht. (Eine neue gibt es übrigens nur zusammen mit der Haube, dazu gibt es hier im Forum schon einen Beitrag. Kostenpunkt aktuell: 90 Euro). Leider tropft das Öl, wenn man vor dem Wagen steht, hinten links raus, d.h. es läuft am/ hinterm Zylinderkopf runter, dringt in den Zahnriementrieb ein, läuft da runter und tropft dann unten von der Riemenscheibe. D.h. ein Teil ist auch auf dem Zahnriemen gelandet. Haltet Ihr das für ein Problem? Zahnriemen neu (hat noch 50000km über) oder ein wenig Bremsenreiniger, ob dem ZR das schadet ? O'The oil has penetrated the tissue so deeply that there's nothing we can do about it.'
It would be great if someone had experience with this and could share their opinion.
I'll probably try sealing the valve cover gasket with Curil to see if it holds.
Thank you very much in advance.
Jens.
Volkswagen Golf 4, 1.9 TDI, 90 hp, AGR engine, 220,000 km - and increasingly more problems.
Translated on 15-07-2026, 16:04.
lappen
Post01-04-2005, 17:49    Subject: Valve cover gasket leak - unfortunately, also on the timing belt. Quote
Hmmm... I know some Audi gasoline engines. They had a problem with oil leaks on the valve cover (or timing chain cover).
I would try to seal the valve covers with sealant. I personally did that on my own car, and it works. For extra safety, I would also replace the timing belt...
Translated on 15-07-2026, 16:05.
Manuel Thomas
Post01-04-2005, 20:20    Subject: Valve cover gasket leak - unfortunately, also on the timing belt. Quote
Remove the cover, verschandeln the gasket, and reinstall it with a little bit of Hylomar http://www.marston.de/dichten/hylomar.php.
And I wouldn't worry too much about a little bit of oil. Just wipe it clean, and that's all there is to it!
Manuel.
Translated on 15-07-2026, 16:06.
christians
Post02-04-2005, 23:28    Subject: Valve cover gasket leak - unfortunately, also on the timing belt. Quote
I don't see this as a minor issue: In my car, which is typical for a five-cylinder engine, there's a leak near the oil pump. The belt is currently slightly oily and has approximately 40,000 km (about 25,000 miles) on it. One tooth is broken at the base. I attribute this to the oil, as 40,000 km out of 120,000 km (75,000 miles) in three years shouldn't necessarily mean the end of its life. (And I'm looking forward to the upcoming work.)
Gruß Christian
Translated on 15-07-2026, 16:07.
Polo2004
Post03-04-2005, 9:32    Subject: Valve cover gasket leak - unfortunately, also on the timing belt. Quote
Hi there,
Okay, I would also seal the valve cover as described above. But I would definitely replace the timing belt. Oil, you know, has a tendency to dry out over time. Sooner or later, that will happen. And eventually, a 'stiff' timing belt will just break...
Best regards, Christian.
Translated on 15-07-2026, 16:08.
No new posts Documentary: Transporter 7D, Timing belt failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A3 ab MJ 98, Zahnriemen läuft auf ESP nicht mittig Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing Belt Replacement: Bolts Too? Diesel Engine Technology
No new posts Ventildeckeldichtung Diesel Engine Technology
No new posts 20m Kabel an Diagnose interface, leider funktionierts nicht! On-Board Diagnostics (OBD)
No new posts Valve Cover Gasket Leak: Easy Fix? Diesel Engine Technology
