Front Spoilers: Materials & Types
Thomas K
Post01-03-2005, 13:07    Subject: Front Spoilers: Materials & Types Quote
The front bumper of my car is slightly torn, likely after someone bumped into it in the parking lot. Now, I want to repair it by plastic welding/gluing and filling, and then repaint it. I've done something similar on my motorcycle before, and it worked quite well.
Can someone tell me what material the front bumper is made of?
"Thank you."
Gruß Thomas
VW EOS 2,0 TSI; BWA; Bj. 06/2006
September 2020 ca. 180.000km
VW Bora Variant, AJM, Bj. 04/2001
04/2016 verkauft mit 378.000km
Translated on 31-10-2026, 3:37.
wolfi_b
Post01-03-2005, 14:00    Subject: Front Spoilers: Materials & Types Quote
I'm quite certain about the material of my rear bumper: it's polypropylene.
I think it will be the same for you / in the front.
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 31-10-2026, 3:38.
Stefan Schlünder
Post08-03-2005, 22:49    Subject: Front Spoilers: Materials & Types Quote
Hello Thomas,
All parts must be marked to indicate the material they are made of. If it's polypropylene, you should find a 'PP' marking somewhere, likely near the date display.
Stefan.
Thomas K
Post09-03-2005, 9:18    Subject: Front Spoilers: Materials & Types Quote
I was actually aware that there should be some kind of abbreviation stamped on plastics. However, I want to start the repair immediately once the apron is removed, so I wanted to have the adhesive or welding material ready beforehand.
Gruß Thomas
Translated on 31-10-2026, 3:39.
René_S
Post04-04-2005, 21:02    Subject: Front Spoilers: Materials & Types Quote
...if the apron is painted, it is not made of PP (polypropylene).
wolfi_b
Post05-04-2005, 6:13    Subject: Front Spoilers: Materials & Types Quote
"However, my rear part is painted and made of PP, while my front part is made of PUR."
1993 Audi 80 B4 1Z
Translated on 31-10-2026, 3:40.
René_S
Post05-04-2005, 20:55    Subject: Front Spoilers: Materials & Types Quote
@wolfi:
...I can't imagine that they are being painted at the Audi paint shop.
@Thomas
Cut off a piece of the bumper in an inconspicuous place and throw it into the water.
If it floats, it should be PE or PP, and you can forget about gluing it. If it doesn't float, you at least have a chance of being able to dissolve it, which could allow you to glue it. We can then determine the type of plastic using a 'burn test.'
René.
No new posts Differences between front bumper for VW Golf 4 4-Motion a... Transmission, Chassis, Body & Interior
No new posts AAT Crankshaft Material Diesel Engine Technology
No new posts G4 ALH: Parts Needed for Timing Belt Replacement Diesel Engine Technology
No new posts LLK Absorbent Pads: Material & Guide. Diesel Engine Technology
