VAG-COM: Increase Engine RPM for Throttle Search
Hati
Post01-04-2005, 19:48    Subject: VAG-COM: Increase Engine RPM for Throttle Search Quote
Hi.
Is there a function in VAG-COM that allows you to temporarily increase the engine speed at idle (without adapting the stored idle speed!) to a specific RPM (in my case, approximately 1700 RPM) until you exit this mode? I'm experiencing a rattling noise that is consistently reproduced at this RPM. To help pinpoint the source of the rattle, it would be easier than having a second person try to maintain this RPM using the accelerator pedal.
Translated on 19-08-2026, 18:37.
Avatar-Jan6K
Post01-04-2005, 19:55    Subject: VAG-COM: Increase Engine RPM for Throttle Search Quote
I only know about the idle speed adjustment, but it doesn't go that high.
Take a wooden wedge and a weight. Place the wedge under the accelerator pedal, put the weight on top of it, and then you can slide the wedge to achieve the desired engine speed.
January.
1Z5 CFHF / AHB H4D
Translated on 19-08-2026, 18:39.
Hati
Post15-04-2005, 12:29    Subject: VAG-COM: Increase Engine RPM for Throttle Search Quote
I eventually managed to fix it together with another man. The oil supply line to the turbocharger had come loose. VW had installed a new charger back in February. Great team. icon_twisted.gif It was, of course, replaced free of charge.
Translated on 19-08-2026, 18:40.
No new posts A4 8E2/8E5 - Possible various error memory messages Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Is it possible to install a G40 engine without replacing ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Automatic Transmission: No Rebuild Needed (01K-01F) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Increase Engine RPM with VCDS (Boost Leak) Diesel Engine Technology
No new posts Is it possible to increase the idle speed on a CAY 1.6 TDI? Diesel Engine Technology
No new posts Heating output as a function of engine speed Transmission, Chassis, Body & Interior
No new posts Engine Speed Sensor | 00801 Diesel Engine Technology
