Fehler: 575 - Leistungseinbrüche bei höherer Geschwindigkeit | Posts 16+
Go to page: Previous  1, 2
Post17-03-2005, 20:51    Subject: Quote
Broken spring inside the can?
Translated on 17-08-2026, 5:21.
sethmuc
Post17-03-2005, 20:53    Subject: Quote
I haven't taken the container apart, so it's hard to say. Generally, do you hear a slight squeaking sound from a spring when the rod is in good condition? (I don't have anything else to compare it to.)
Post17-03-2005, 21:43    Subject: Quote
sethmuc wrote:
I didn't take the can apart, so it's hard to say. Generally, do you hear a slight squeaking sound from a spring when the rod is okay? (I don't have anything to compare it to).
Well, the mechanics aren't designed to be silent, so you can definitely hear it moving.
I don't recall hearing any squeaking sounds with my AFN.
Translated on 17-08-2026, 5:22.
sethmuc
Post17-03-2005, 22:00    Subject: Quote
Well... I actually wanted to avoid unscrewing the can, but apparently there's no other option icon_wink.gif.
'//edit: So, you remove the two nuts underneath the can, and then somehow you can pull the rod out? What kind of mechanism is behind that? (I just want to make sure I'm not doing anything wrong).'
And are you sure it's unlikely to be the solenoid valve for turbocharger pressure regulation or the exhaust gas recirculation (EGR) valve?
Greetings.
Translated on 17-08-2026, 5:23.
Post17-03-2005, 22:55    Subject: Quote
Have you ever watched "Turbo"?
Have you already looked at the URL I posted?
Okay, hier ist die Übersetzung:
"Here it is again:"
http://www.technologie-entwicklung.de/Gasturbines/VNT15-Turbo/vnt15-turbo.html
Here you can see perfectly how to get the can out:
Remove the two screws and the retaining ring at the other end of the control rod.
Sure, installing a turbocharger might be a bit tricky, but that's why there are so many pictures available beforehand, so you can see what to expect.
m,
Translated on 17-08-2026, 5:25.
sethmuc
Post18-03-2005, 19:56    Subject: Quote
Have you ever watched The Turbo?
I apologize if that came across as a bit wrong. Of course, I looked at the picture – but I just wanted to make sure there wasn't anything specific to be aware of, besides what's mentioned in the technical articles/link about the turbo. My concern was purely about safety icon_wink.gif (no offense intended).
Translated on 17-08-2026, 5:26.
sethmuc
Post26-04-2005, 16:17    Subject: Quote
Hi, I just wanted to close this thread with the results of what came out of it:
Indeed, the shaft was completely immobile, and after I installed a new turbocharger, all the problems were solved icon_wink.gif.
Thank you very much for all the tips!
Translated on 17-08-2026, 5:27.
No new posts VW Golf V/VI and similar models: ABS/ESP error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Why higher fuel consumption at lower outdoor temperatures? Diesel Engine Technology
No new posts After reading the error memory, the mileage suddenly incr... On-Board Diagnostics (OBD)
No new posts 1.9 TDI ATD: Power Loss & Soot Issues Diesel Engine Technology
No new posts Stunning performance drops at 1Z Diesel Engine Technology
