Stop Oil Leaks: Repair & Prevention
Juergen
Post02-10-2002, 12:36    Subject: Stop Oil Leaks: Repair & Prevention Quote
Hello everyone!
I'm having problems with a leaking gearbox.
Approximately 4 years ago, a 'specialized workshop' replaced the clutch. During the process, the transmission housing was unnecessarily opened, and instead of using new flange gaskets during reassembly, these 'experts' used a liquid sealant (permanently elastic).
To put it simply: The transmission oil found a way through this sealant material, and it succeeded.
Since I don't feel like disassembling half the car to install the flange gaskets, my question is:
Has anyone had any experience with 'miracle' products like 'LECKWEG', 'ÖLVERLUSTSTOP', or similar products?
Does this stuff actually work, and if so, for how long?
I would be very grateful for any kind of advice!
Best regards, Jürgen.
Translated on 04-10-2026, 6:55.
Post02-10-2002, 13:20    Subject: Stop Oil Leaks: Repair & Prevention Quote
Hello Jürgen,
I once tried using an oil leak stopper on a 1.6D engine where the rear of the head gasket was slightly leaking oil towards the driver's side.
It didn't achieve much, and the oil consumption afterwards was about 50%.
Translated on 04-10-2026, 6:57.
No new posts ATF oil leak on 74 kW TDI engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Oil Leak MKB AKF: Oil Level Sensor Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Oil Leak Motor Block: AFB & AKN Engine Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A8: Start-stop system doesn't always work Diesel Engine Technology
No new posts 1.6 TDI: No dual-mass flywheel with start-stop function Transmission, Chassis, Body & Interior
No new posts MFA Failure: Engine Stalling at 120 km/h Diesel Engine Technology
No new posts TDI AWX Oil Leak: Causes and Solutions Diesel Engine Technology
