Audi 100 2.5 TDI: Adaptation Channels?
Andi aus dem Ösiland
Post04-05-2005, 19:40    Subject: Audi 100 2.5 TDI: Adaptation Channels? Quote
Hello!
Does anyone know if it's possible to adjust the fuel injection amount through adaptation in this specific system/device?
I went to the dealer today, and he tried using the 'Blue Box' (I don't know the exact name), but it failed. The login didn't work!
The expert there also said that the workshops don't actually have the login codes; he just obtained them privately from somewhere! icon_confused.gif It seems a bit strange to me.
If it's not possible to do it this way, I'll have to make the changes directly in the software (it's just a bit tedious to burn an EPROM for every attempt).
Andi.
Translated on 10-08-2026, 4:41.
Trecker Treiber
Post04-05-2005, 21:51    Subject: Audi 100 2.5 TDI: Adaptation Channels? Quote
Hello there.
The topic has been discussed before; you can find more information here.
/viewtopic.php?t=683
Translated on 10-08-2026, 4:42.
Post05-05-2005, 9:44    Subject: Audi 100 2.5 TDI: Adaptation Channels? Quote
Sure, I know that post. But he has an A6 C4, which has a completely different control unit.
Well, I actually only asked the question because my car was at a workshop two years ago due to complaints about excessive soot (I was still a relatively new automatic transmission driver back then and thought something might be broken).
'The workshop then connected their diagnostic equipment and, according to the master mechanic, slightly reduced the fuel injection amount. Now I'm wondering if that was just talk, because the workshop I visited yesterday couldn't do that!'
Well, I'll know on Monday, because that's when someone will come and knock to reverse the process.
Greetings,
Andi.
Translated on 10-08-2026, 4:43.
No new posts Adaptation Channels of Engine Control Unit Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Differences in MSG for Audi 2.5 TDI AAT engines On-Board Diagnostics (OBD)
No new posts Audi A6 TDI: Intermittent Starting Problems Diesel Engine Technology
No new posts OT Markierungen beim Audi A6 2.5TDI ??? Diesel Engine Technology
No new posts VAG-COM communication problem with Audi 2.5 TDI (4B) On-Board Diagnostics (OBD)
