MSG und KI anpassen 115PS TDI VAG | Posts 16+
Go to page: Previous  1, 2
wutz
Karma: +11 / -1   Thank you, like it!
2006 Seat Leon
Post24-03-2005, 15:15    Subject: Quote
Well, I'm basically looking for a needle in a haystack.
ECU with FIS (multifunction display) and without CAN bus (part number 1JO 919 xxxx) for my diesel engine, speedometer up to 220 km/h.
Unfortunately, they are not that common.
Out of desperation, I'm currently working on building my own FIS display.
It's not that easy for me either (I only have basic knowledge of electronics).
Translated on 27-09-2026, 15:27.
mullemaus
Post24-03-2005, 22:06    Subject: Quote
'Vehicles manufactured in 1999 have WFS 2, and those manufactured in 2002 have WFS 3. As you already noted, it's hardly possible to adjust the WFS. This has almost nothing to do with the CAN bus. The engine and the MSG (Engine Control Module) that we just installed also have a CAN bus. However, the engine still runs perfectly. The error is just stored in the memory.'
Translated on 27-09-2026, 15:28.
Jaxx
Karma: +0 / -2   Thank you, like it!
Post03-05-2005, 8:30    Subject: Quote
And the conclusion? I would also like to install an XXX 920 XXX TAcho in my 12/98 Passat, which previously had an XXX 919 XXX TAcho. Does anyone now know if this is possible and how to do it?
Best regards, Jaxx.
Dan.jel
Post03-05-2005, 15:20    Subject: Quote
gti-tdi.de
They now even have adapters available.
Translated on 27-09-2026, 15:29.
Jaxx
Post04-05-2005, 12:14    Subject: Quote
Could it be that it sometimes works like that?
Ich hatte denn neuen Tacho(mit Can) mal angeschlossen(an Fzg. o. CAN) and
I then read out the CAN gateway, which previously only showed one error.
and then the tool said something like "[K<->CAN Gateway]"!
Besides the brake pad wear sensor, everything else is working, from the MFA (Multifunction Display) to the WFS (Wireless Keyless Entry System), but the WFS still doesn't recognize my keys.
Best regards, Aaron.
Passat 3B Variant TDI Fjordblau Bj.12/98 145PS Comfortline Epia CarPC Chip bei 230tkm und läuft und läuft... (bis jetzt 300tkm)
Translated on 27-09-2026, 15:30.
mullemaus
Post05-05-2005, 22:10    Subject: Quote
In some cases, there were mixed installations. There were instances where a 920 speedometer was installed in a vehicle that previously had a 919 speedometer... These are vehicles from the later 919 production run and the early 920 production run.
Jaxx
Post06-05-2005, 12:33    Subject: Quote
I'm sorry for being presumptuous, but do you know that, or are you just thinking that?
Translated on 27-09-2026, 15:31.
No new posts Differential pressure sensor G450 to be calibrated/adjust... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Chip tuning for PD TDI 115hp, manufactured in 2004 Diesel Engine Technology
No new posts Loader Charger 115HP & Control Valve Diesel Engine Technology
No new posts 115 HP PD AJM engine without longlife oil? Diesel Engine Technology
No new posts Weak Acceleration: PD 115HP Engine Issues? Diesel Engine Technology
