Diagnostic Tools: Store-Bought vs. DIY?
joop
Post02-10-2002, 15:44    Subject: Diagnostic Tools: Store-Bought vs. DIY? Quote
I would like to know if the purchased hardware is fundamentally 'different' in its construction compared to a self-built system.
The DIY version uses an optocoupler as the main component. What about the purchased connector? Does it also contain optocouplers?
Has anyone seen a circuit diagram for the K1-K2 function?
best regards
Okay.
Translated on 13-10-2026, 5:30.
Post02-10-2002, 15:47    Subject: Diagnostic Tools: Store-Bought vs. DIY? Quote
Hello Joop,
At least my adapter from DRV is potted, and there's a high probability that others are doing the same.
Therefore, it will probably be difficult.
Translated on 13-10-2026, 5:31.
Post03-10-2002, 20:21    Subject: DIY vs. Purchased Diagnostic Tools: Which is Best? Quote
joop wrote:
The DIY version uses an optocoupler as the main component, but what about the purchased connector?
Are optocouplers also used inside? }
Hi.
As a possible indicator, you could measure the Ohmic resistance between pin 5 of the RS232 connection and pin 4 of the onboard connector.
A reading of zero ohms would indicate that there is no isolation provided by the optocoupler.
Translated on 13-10-2026, 5:32.
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts Eberspächer Heater Diagnostics: Troubleshooting Guide Troubleshooting & Guides
No new posts VCDS: On-board diagnostics for VAG vehicles Troubleshooting & Guides
No new posts DIY Adapter: Build Your Own Adapter Diesel Engine Technology
No new posts VTG 17 vs. VTG 15: What's the Difference? Diesel Engine Technology
No new posts AAT vs. AEL: What's the Difference? Diesel Engine Technology
No new posts 1.9 TDI vs. 2.5 TDI: Differences in smoke emissions? Diesel Engine Technology
