Car Repair Problem? Get Expert Help Now!
Basti911
Post06-10-2002, 10:04    Subject: Car Repair Problem? Get Expert Help Now! Quote
Hi!
I have the following problem with my Passat TDI, model year 1994, 90 hp (1Z), with 306,000 km:
When driving at a constant speed in the lower RPM range (1500 to 2250 RPM), it jerks or shudders (I can't think of a better word).
Even at idle, the engine speed is relatively constant, but there is still some hesitation. The problem occurs regardless of the temperature.
I took my car to a workshop where the engine control unit was scanned, and no errors were found, not even with the fuel injection pump, which the mechanic had suspected.
The mechanic described the problem as 'sawing' and said to just keep driving and observe icon_confused.gif.
I once cleaned the LMM (but it didn't help), and the car is actually still running well. So, it would be great if someone here could offer some advice.
Thank you in advance, BASTI!
Translated on 07-09-2026, 2:35.
Post06-10-2002, 17:28    Subject: Car Repair: Mechanic Can't Fix It? Get Help! Quote
Please use the search function (e.g., "pumping jerk," "jerking"). Ulf and I have extensively discussed the issue of "pumping jerk" in the 1Z engine (and also in other VE models).
My jerky 1Z has been jerking since Friday... it has been sold!!
Translated on 07-09-2026, 2:36.
No new posts Skoda Octavia 1U: Change dashboard illumination to white Troubleshooting & Guides
No new posts DPF not regenerating Troubleshooting & Guides
No new posts Not LLM: Poor Performance Explained. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi 1Z Power Loss: Troubleshooting & Solutions Diesel Engine Technology
No new posts Corroded VTG rod, don't know what to do next. Diesel Engine Technology
No new posts TDI Problems? Get Help Now! Diesel Engine Technology
No new posts Performance loss and no one knows what to do On-Board Diagnostics (OBD)
