Beetle TDI will nicht. "Bremse" bei ca.2500U/min | Posts 16+
Go to page: Previous  1, 2
96kwtdi
Post18-05-2005, 8:21    Subject: Quote
Hello Rainer!
He said that, in terms of the effort involved, icon_rolleyes.gif readjusting it is equivalent to changing a timing belt.
Greetings.
Translated on 14-08-2026, 20:36.
Post18-05-2005, 8:34    Subject: Quote
Hi.
Can you see and touch the fuel injection pump rotor?
Sure? Then it's doable in under 30 minutes, and you'll still have plenty of time if you don't have to spend the first 20 minutes gathering your tools like I do.
96kwtdi
Post18-05-2005, 8:40    Subject: Quote
Hello!
I have no idea how it is with the Beetle icon_rolleyes.gif. I only know that you absolutely cannot get to the turbocharger properly because it's located behind the splash guard in the Beetle. You can't even reach it with your hand if you just want to touch it, let alone take anything apart icon_evil.gif.
What surprises me is... normally, the TDI runs fine if the injection timing is close to the limit. Does this only become noticeable during startup? I always thought that the TDI wouldn't run properly at all if the injection timing wasn't set correctly icon_rolleyes.gif.
Greetings.
Translated on 14-08-2026, 20:38.
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat B7 FN3 brake, 16" to C60 17" conversion/reprogramming On-Board Diagnostics (OBD)
No new posts Euro 4 requirement not as "absolute" as previously thought? Diesel Engine Technology
No new posts Strange "wobbling" when not accelerating Diesel Engine Technology
No new posts Peugeot 406: "ECU Not Found" Error - Fix On-Board Diagnostics (OBD)
