Oil Leak Motor Block: AFB & AKN Engine Repair (Solution)
Michael II
Post08-10-2002, 15:28    Subject: Oil Leak Motor Block: AFB & AKN Engine Repair Quote
Oil leak/leakage at the engine block (AFB, AKN engine).
Cause:
The bearing caps for the crankshaft bearings are fastened to the outside of the engine block with screws. In isolated cases, the threads in one of the caps may become damaged.
der Lagerdeckel nicht tief genug gebohrt wurde. The suit.
The torque of the screw is reached before the screw...
kopf am Motorblock anliegt und abdichten kann. About running.
Over time, this can manifest as oil loss. Since the location is...
If it is difficult to see, there is a possibility of...
"Interchangeable with an oil pan that has a leak."
Procedure:
Remove the affected screw and file it down by approximately...
1,5 mm kürzen. Schraube mit 25 Nm festziehen. Additional.
No sealant is required.
Tschüss
Michael II
Translated on 22-09-2026, 8:42.
Ratings - Oil Leak Motor Block: AFB & AKN Engine Repair
No new posts Document: Severe oil leak at the cylinder head, AJM engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ATF oil leak on 74 kW TDI engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Oil Leak MKB AKF: Oil Level Sensor Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Ölverlust beim VW 1.9 TDI PD-Motor - Kennbuchstabe ARL Diesel Engine Technology
No new posts Oil Leak V6 TDI: Causes & Fixes Diesel Engine Technology
No new posts Engine Block Clutch Bell Diagram Diesel Engine Technology
No new posts AAT Cylinder Head: Fits 1T Engine Block? Diesel Engine Technology
