Taxiratte Blaumann
03-05-2005, 12:49 Subject: Clutch Slipping: Causes and Solutions |
I have the following problem with my Passat 3B (01/00) with an 85 kW PD engine:
"As soon as the car is put into a higher gear, the clutch starts to slip. Slipping the clutch becomes possible only at approximately 1400-1600 RPM; below that, the engine will stall quickly. This problem seems to be temperature-dependent (it's more likely to occur in warm weather). If the car is left standing for a few hours or driven for a long distance without shifting, everything normalizes again. The clutch now has approximately 80,000 km (50,000 miles) on it. This issue also occurred with the previous clutch, around 60-80,000 km (37-50,000 miles). The old clutch was replaced as part of a complete engine overhaul at approximately 170,000 km (105,000 miles)."
The old (clutch) assembly was in good condition; the friction surface was clean, the springs were intact, and there was no corrosion. The pads had only about 1/3 of their material worn off.
Does anyone have any idea where this plucking might be coming from? Meistens: Passat (1/00,1,9L, 85KW PD, 280tkm)
Abgemeldet: Passat 32B (11/88, 1,6L, 40KW, 550tkm)
Translated on 13-08-2026, 18:14.
Mephisto Profi-Schrauber
03-05-2005, 14:35 Subject: Clutch Slipping: Causes and Solutions |
"When you say that the old clutch still had about 1/3 of its lining left at around 170,000 km and was slipping, it reminds me of my time with Ford. There was a problem where the clutch lining would become extremely smooth over time when the clutch wasn't under much load, which then led to the slippage you described. I got the tip to start in third gear and let the clutch slip slightly, which actually helped."
If I remember correctly, there used to be another thread in this forum about a clutch that was slipping. As far as I recall, the entire issue was resolved with a single action.
"Micha"
Translated on 13-08-2026, 18:17.
Taxiratte Blaumann
09-05-2005, 13:51 Subject: Clutch Slipping: Causes and Solutions |
I once did a test when the clutch was back to its "normal operating temperature":
When I hold the car with the brake and keep the clutch at the friction point, everything works smoothly (no jerking). However, as soon as I release the brake and the car starts to move, it begins to jerk.
It appears that the "jerking" only occurs when the clutch is warm and there are differences in speed between the disc and the flywheel, specifically below 800 RPM. Meistens: Passat (1/00,1,9L, 85KW PD, 280tkm)
Translated on 13-08-2026, 18:18.
T3Surfer Profi-Schrauber
Joined: 09/17/2004 Posts: 1833 Karma: +34 / -0 Location: Frankurt 2001 Seat Toledo Premium Support
05-06-2005, 20:16 Subject: Clutch Slipping: Causes and Solutions |
Hmm, it sounds like a dual-mass flywheel issue. Perhaps the oil in the DMF is not damping as effectively when hot because it has become too thin. That's my guess. I'm not entirely sure if my theory is correct, though! Feel free to correct me. NA,Gehörlose wie ich können auch Schrauben! Ihr HÖRT ich FÜHLE! T3 TD EX-JX Jetzt 1Z mit 122PS und Renaultgetriebe Golf II TD Bj 84 512Tkm Passi 35I 1Z 468Tkm--> Seat Toledo AHF-- Toledo ARL 477Tkm mit Spritspartuning  99er T4 Syncro-Cross 100800km grad eingefahren
Translated on 13-08-2026, 18:19.
Profile PM Email Garage |
Danilo100 Blaumann
Joined: 03/18/2004 Posts: 12 Karma: +7 / -0 Location: Dorsten
06-06-2005, 19:41 Subject: Clutch Slipping: Causes and Solutions |
Hello.
In a dual-mass flywheel, there are suspension elements installed; there is no oil involved!
Danilo. Golf 1J/5, Bj99 MKB: ALH , GKB: EBJ , GRA, Box
VW Passt 3BG Variant AVF, 6 Gang, GRA
Skoda Octavia Combi 2.0 TDI BKM DSG 170PS
Translated on 13-08-2026, 18:20.
Profile PM Email |
mullemaus Guest
08-06-2005, 0:09 Subject: Clutch Slipping: Causes and Solutions |
Hello.
And they are even made of rubber  .
The 2MSR issue with the AJM engine (resulting in 115 hp) is well-known, and there was even a VW recall campaign related to it, specifically in the Passat. However, if your car was manufactured in 2000, you might already have the ATJ engine  .
Problem description: Severe vibrations or jerking at idle in engines with the engine code AJM and a 5-speed manual transmission.
Cause: Imbalance in the dual-mass flywheel can cause strong vibrations, especially when idling.
Change: Conceptual change involving the use of an ATJ engine.
Customer service solution: In cases of persistent complaints, please contact your product support team.
Conclusion: To step on someone's toes  .
Translated on 13-08-2026, 18:22.
