TDI V6: Documenting Engine Power Loss Issues (Solution)
Post02-05-2002, 15:07    Subject: TDI V6: Documenting Engine Power Loss Issues Quote
AKN/AFB engine, TDI V6.
Gradual decrease in engine power over time and mileage.
No errors are stored in the engine control unit.
Cause:
Oil mist can gradually accumulate on the sensor membrane when the engine is stationary.
The air mass meter signal becomes increasingly distorted until a noticeable loss of power occurs. Due to the slow change, an error message is usually not recorded.
Solution:
Check the mass airflow sensor. Compare the target and actual values of the air mass being drawn in, as displayed in measurement block 10, under load.
Replace the mass airflow sensor if the target values are not being reached.
Check the air filter element.
See also: https://community.dieselschrauber.org/en/viewtopic.php?t=1266&highlight=v6+luftmassenmesser
Author: Michael II
Translated on 29-07-2026, 21:23.
Ratings - TDI V6: Documenting Engine Power Loss Issues
No new posts TDI Engine Problems: Low Power & Error Code 00553 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt wear - models MJ 1996/1997/1998 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4 8D: Documenting Performance Issues Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Power & RPM: Explained Simply Diesel Engine Technology
No new posts Question about engine power Diesel Engine Technology
No new posts Brake Performance and Engine Power Transmission, Chassis, Body & Interior
No new posts Engine Power Loss & Glow Plug Light On? Diesel Engine Technology
