Two days ago, I posted a message (see June 22, 2005, 'Why does the TDI start so poorly?') where I described significant starting problems.
Now I've readjusted the fuel injection system and bled the ESP (a lot of air bubbles came out), and sure enough, the car starts perfectly again, even after being idle for a long time!
In the first exam for the SB course, I had an awful time, which I absolutely don't understand.
How can the SB (Steuergerät/control unit) adjust itself if there are no adjustments being made to the timing belt?
Does anyone have an idea? Because if this happens once, it will happen again, because the cause hasn't been addressed or identified!
Kisses.
