VAG Com - Easily make adjustments
OlliP
Post04-10-2002, 11:40    Subject: VAG Com - Easily make adjustments Quote
I got a demo version of VAG-COM and I want to...
Let's just make a change to add some feeling.
to get involved in the matter. I have selected the following for this purpose.
The central locking system!!! I would like to set up that...
The control valve closes after the system has reached its operating pressure. Of course, I don't want anything.
'I'm going to break something and I'm asking here first!'
Is there a guide for that?
Thank you.
Olli.
DocSnydor
Post04-10-2002, 13:20    Subject: VAG Com - Easily make adjustments Quote
Small tip: Check the error database (2. Page ) under 'Central locking system adjustment options' or something like that...
OlliP
Post07-10-2002, 11:54    Subject: VAG Com - Easily make adjustments Quote
'Thank you.' I've looked at everything, but I'm still unsure.
Not quite so sure!!!
1. Will this also work on my Seat Leon, manufactured in 2002?
2. Is this also 'Olli-Sicher'?
CU
Olli.
Post07-10-2002, 14:05    Subject: VAG Com - Easily make adjustments Quote
OlliP
Post10-10-2002, 21:14    Subject: VAG Com - Easily make adjustments Quote
...and then the 'this is going to be expensive' light comes on???
Thank you.
Olli.
DocSnydor
Post11-10-2002, 7:25    Subject: VAG Com - Easily make adjustments Quote
OlliP
Post11-10-2002, 10:24    Subject: VAG Com - Easily make adjustments Quote
THANK YOU for the encouragement!!
Do the Audi parts fit my SEAT?
CU
Olli.
Michael II
Post11-10-2002, 10:40    Subject: VAG Com - Easily make adjustments Quote
The data from Audi (usually encoded using control unit codes) is not the same as the data from VW (usually encoded using adaptation channels).
As you may already know, SEAT is concerned about... The technology is closer to Volkswagen than to Audi.
Therefore, you should try the Volkswagen approach.
If you don't have enough experience and knowledge yet, you should probably spend some more time browsing this forum before you start trying things out.
Tschüss
Michael II
OlliP
Post11-10-2002, 11:07    Subject: VAG Com - Easily make adjustments Quote
That is not correct!!
My LEON is (almost) an A3, and SEAT is a subsidiary of AUDI.
SKODA is a subsidiary of VW!
AUDI - SEAT - Lamborghini
VW - SKODA - Bentley
This is what the corporate structure looks like!
Correct me if I'm wrong.
CU
Olli.
Michael II
Post11-10-2002, 11:35    Subject: VAG Com - Easily make adjustments Quote
Unfortunately, the corporate structure (which, by the way, hasn't been in this form for very long) is not reflected in your engine control unit (ECU) coding.
Tschüss
Michael II
OlliP
Post11-10-2002, 11:56    Subject: VAG Com - Easily make adjustments Quote
Okay, clear statement.
Does that mean I can use the VW data?
Jan6K
Avatar-Jan6K
Post12-10-2002, 10:17    Subject: VAG Com - Easily make adjustments Quote
Hi Olli,
It doesn't necessarily work for every car. For example, in the Ibiza 6K, it doesn't work with either the VW or Audi codes to access the central locking module, because, according to Michael II, it's not connected to the K-bus. Someone already asked about the Leon in the auto-intern forum, but as far as I know, it didn't lead to any results.
Do you actually see the ZV module with VAGCOM?
Otherwise, I agree with Michael; almost everything else about the Ibiza is very VW-like.
Jan.
1Z5 CFHF / AHB H4D
OlliP
Post12-10-2002, 19:27    Subject: VAG Com - Easily make adjustments Quote
Okay, so I've tried it all out now!
Michael is right - VW works.
And Rainer is, of course, also right.
TRY AND SEE! (or TRY AND FIND OUT!)
/Happy one
IT WORKS.
/Happy out
CU
Olli.
No new posts Einstellung der Einspritzdüsen/Düsenhalter eines VP-TDI Troubleshooting & Guides
No new posts VCDS: Adjusting Glow Plug Timer on VAG TDIs Troubleshooting & Guides
No new posts A3 TDI: Engine Stalling - Common Problem? On-Board Diagnostics (OBD)
No new posts TDI Engine Failure: Common Causes & Fixes Diesel Engine Technology
No new posts NSL sometimes just lights up for no reason! Diesel Engine Technology
No new posts Golf V TDI 2.0 PD: Engine Stalling Issues On-Board Diagnostics (OBD)
